Tractor Tire Size - is bigger always better? (width, diameter, aspect ratio)
   / Tractor Tire Size - is bigger always better? (width, diameter, aspect ratio) #11
Wider=less soil compaction, is pretty much always true. Ride quality; it might be worth looking at the recommended PSI for the tires. All things being equal, higher PSI =rougher ride.
   / Tractor Tire Size - is bigger always better? (width, diameter, aspect ratio) #12
I like today's 4wd tractors that have a lower aspect ratio in the front tires which makes sidewall stress and flexing much better (less) than older FEL designed tractors of which I have/had both excluding my 4010 and 4020 JDs with 9x or 11x (as I recall) width 8 ply tires.....the 9x on the 10 a little iffy as far as ground contacting support was concerned....with a full bucket on soft ground it sank more than I wanted......but what did you expect.....yes..........
   / Tractor Tire Size - is bigger always better? (width, diameter, aspect ratio) #13
Consider carefully, they last a long time (you’re kind of stuck with them. I would go wide and tall as possible. Keep an eye on the sidewall plies and load capacity for the fronts for loader work.
I like Trelleborgs and BKTs for good tires at a good price.
Wow, that was a long delay. i'm sorry about that. i thought I had replied earlier.
I chose these tires: MICHELIN BRAND R1W TIRES: REAR TIRES 520/85R38, FRONT TIRES 420/85R28
The tractor was ordered in Nov 2023 and I'm expecting delivery of it in late July 2024 (in a few weeks, I hope).
Thanks to each of you for taking the time to write and teach my about tire tradeoffs and preferences.
   / Tractor Tire Size - is bigger always better? (width, diameter, aspect ratio) #15
that looks like a good choice.
Ive seen a couple of dealer videos online that are ordering radials on the new tractors. It looks like a squarer profile on R1's and wider as well.
They should be somewhere between R1 and R4 on ride quality. R4 to me ride much better on rough ground but I hate that most manufacturers of tractor choose lower profile R4's.
Let us know how those tires you got do.
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
New/Unused Agrotk Tire Changer (A57454)
New/Unused Agrotk...
2016 PETERBILT 579 (A58214)
2016 PETERBILT 579...
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
PEDESTAL FAN (A58374)
