Tractor Tire Pressure
/ Tractor Tire Pressure #11
No question, with FEL that you actually use, max pressure in front tires as stated on the tires themselves. Many reasons this is the right answer.
/ Tractor Tire Pressure #12
pat32rf said:
I tend to take the other side of the coin. I have a lot of sharp rocks and sticks, not to mention bumps. I learned (on my 4x4s)a long time ago that a softer tire is less apt to get a hole poked in it, gives better traction and floatation, and a much smoother ride. The tires should have some flex (but not enough so it pinches the sidewall against the rim)
Going over a stick or stone with a hard tire can tilt your tractor real quick, but if your tire can conform to the stick you won't feel it as much. This is even more evident with a rear tire.
Used to always run oversized tires on the little(3-4000lb) 4x4s at about 12-15psi and get even tread wear and a smooth ride, excellent traction. (Then when they went to a garage for an oil change they would come back with 25-35psi in them.)
pat, I agree with your reasoning but only for my rear tires - I run my rears a little soft for exactly the reasons you state, but I keep my FEL on all the time and use it almost every time I run the tractor so I keep full pressure in the fronts. Even at full pressure, my 6' bucket full of dirt or gravel will squat the tires some, makes steering a little harder and on uneven or hilly ground it can make you squeeze your cheeks a little tighter to the seat, especially making a turn going downhill. I've had the rear wheels dancing off the ground before and was sure glad those front tires were up to par!
/ Tractor Tire Pressure #13
Pat.. i have to agree with Roy.. you must not run a heavilly laden FEL often.
I move round hay bales with my loader.. if I ran anything under max pressure.. the tires' flatten right out and roll of fthe rim as soon as i turned...
And yes.. we've all had sticks poke our tires and had to fix flats... it's just aprt of owning a tractor.
soundguy
/ Tractor Tire Pressure #14
soundguy
Just part of the "fun"......
The way I had it explained to me by the tire guy who fixes our back hoe tires, you need enough pressure so that the sidewall doesn't bow more than 1/4th of it's height under the heaviest of loads. Then, you need a TIRE that's rated for AT LEAST enough pressure to handle that inflated psi. Excessive bowing of sidewalls, even with "enough" pressure will usually lead to premature tire failure.
Loaders are tough on tires. No amount of air changes that.
/ Tractor Tire Pressure #15
Yep.. and the more ply's the better.
I got 1 loader with 6 ply tri-ribs... I have to run the small bales on her.. just not enough tire up there.
The other loader is on a beefier 8 ply quad rib... properly aired.. she runs anything the loader will grunt off the ground..
( and as everything in the world is.. the 8ply quad-ribs are $pendier than the 6ply tri-ribs.. )
Soundguy
/ Tractor Tire Pressure #16
Actually I use my loader constantly, sometimes with loads that I have to curl to get off the ground(not often) Bought the tractor new because of the loader and have about 3000hrs on it now. My work is virtually all off road and in the bush.
What I was trying to get accross was that it is OK to have some flex in the front tires with a loaded bucket. You do not have to increase the air so they are rock hard. You may be better off with a bigger(wider)front tire of higher capacity. The amount of flex will of course depend on the load.
I have a "rock fork" that I use for big boulders and sometimes have to run the loaded forks up a hump, then curl the bucket to get the load off the ground. This means that it is well over 1200lbs. (JD 4300) Then my tires squat more than I like to see, to the point that I worry about them but I do everything slowly with these loads.
I don't remember what my tire pressure is but go by what works. My only front flat was when I found a nail and I once knocked loose a rear valve, but made it back to my float to pull the tire, by hooking one corner of the loader under the float to lift the opposite rear off the ground.
/ Tractor Tire Pressure #17
Has anyone seen a "zipper failure" on a tire? In a nutshell, it is caused by having excessive sidewall flex and then airing up the tire to higher, but normal pressures. The cords in the sidewall are damaged by the excessive flexing when run at a low pressure and they fail when the tire is aired up again.(fyi 20 percent underinflated is considered a run-flat by tire manufacturers). Sidewall zipper failures typically occur during the inflation process. There is almost no way to determine whether a tire is subject to zipper failure. The sidewall of a tire catastrophically fails, often injuring, sometimes killing the inflator and/or bystanders. These failures are referred to as "zipper failures" because of the appearance of the sidewall after the explosion. However, tires are designed to run at a specific inflation pressure. Overinflation reduces a tire's footprint and places more weight on the middle of the tread. Not only will this reduce a tire's life, but ride quality, stability, safety and traction all can be compromised.
/ Tractor Tire Pressure #18
Welcome Aboard Mace! Well put about tires and pressures. I have a compact with FEL on all the time. I run the fronts at the max as listed on the tire. For the rears, I finally settled on 10 lb after driving it on new limestone with various loads and seeing which pressure left the lugs entirely white and yet didn't mark the sidewalls with limestone dust -- the logic being that meant the lugs were in good contact while the sidewalls were not flexing excessively. I carry 130 lb on each rear wheel and either a blade or several hundred pounds on the rear hitch.
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
Hilti TE 2000-AVR Electric Jack Hammer (A60352)
Hilti TE 2000-AVR...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
