There are a lot of variables to this. First most likely the tractor will not tip near as easy as you think. Believe most here will tell you they have come out of the seat thinking it was going but it remain upright. Not saying do not be safe, far from it.
You may wish to look at videos on the internet of tractor accidents to get an idea of how far some are pushed before they do roll and they will roll and yes kill.
Some suggestions:
On slopes you are less stable driving sideways, better straight up and down.
Slow is better than fast, a tractor will slower travel over something at high speed that may have bounced crossing and rolled.
Wider wheel spacing is better, check your manual for wheel spacing.
The type of implement you have attached can help make you more stable or less. Wide implements may make you more stable.
Load (even implements) lower are more stable then raised. Of course you must lift them some to transport but if tractor is tipping towards a load, lower it as fast as possible and that may stop the tipping. Say you have heavy load on the rear hitch for front end loader, you drop the load if possible if it tips that direction.
Be sure to keep check on tire air pressure, you do not want a low pressure tire to come off the rim on slope.
Be sure you understand how the brakes work before you get on a slope and you may want to lock so both bake together.
I would suggest you take the tractor only, if it is four wheel drive I would use it and in low gear and slow ground speed with say 15000 rpms so the hydraulics are working pressure and quick response get out there and drive across the different concerns. Begin with one you feel very comfortable with and work up. When you are comfortable at low speed then move up in speed some. Watch you front tires (you will not be able to see rear ones unless in trouble) for lifting off the ground. If that begins to happen-STOP. Land here is mostly level but have had people killed or injured and all the cases I know of were tractors rolling over into ditches (other than accident with auto) or into holes. I really think you will find them much more stable than you think they are. Oh if you have roll bar do wear the seat belt for it should keep you within the roll bar if the tractor rolls. If no roll bar do not wear seat belt. kt
