Tractor Supply Hy-Trans Fluid...
   / Tractor Supply Hy-Trans Fluid... #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
For you guys that use the Tractor Supply Hy-Trans Fluid...
It is on sale this week for 24.99 per 5 gal bucket...
They also have Rotella for 29.99 per 2-1/2 gal...
I don't know if this is a regional price reduction or not...
   / Tractor Supply Hy-Trans Fluid... #2
The fluid that is on sale " Xtreme® Tractor Hydraulic & Transmission Fluid, is a brand that they started selling about a year ago, They're house brand is Traveller® Universal Tractor Trans/Hydraulic Fluid which I have been using for almost 10 years now and have confidence using....... At 24.99 a 5 gal.pail
its tempting - but !!!!!! I'll wait for TBN members to share they experiences with this brand
   / Tractor Supply Hy-Trans Fluid... #3
I use the Traveller PREMIUM trans/hyd fluid in my tractor with HST and use the Xtreme fluid to top off my hydraulic reservoir in my TLB. I would not use it in an HST tractor because of the higher tolerances in the HST. The premium fluids seem cheap by comparison to a failed HST. I think if I lived in a cold climate, I would use only New Holland Multi-G 134 or F200A synthetic for extremely cold climates.
   / Tractor Supply Hy-Trans Fluid... #4
In the "New Holland News-Fall 2013" there is a 2 page article promoting their SystemGuard fluid analysis program.
It is about sending in fuel, oil, hydraulic fluid, and coolant samples from your tractors, at 250 hour intervals, for lab analysis to indicate pending problems in the systems.
With this, and a new change to their Mastergold Engine oil and Mastertran transmission/hydraulic oil they are talking extended service life for seasonal use equipment and up to 600 hours between engine oil changes for the newer Tier 4A compliant engines.
The article is titled, "Fluid Analysis Gains Traction as Change Intervals Expand"
It is probably available for on-line reading, and I imagine all the major tractor manufacturers have a similar program.
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
