Tractor suddenly shuts off
   / Tractor suddenly shuts off #1
trook
North Central Mississippi
JD 5075E Cab
I own a 2009 JD 4320 with 250 hrs. I have had absolutely no problems up to this point. However, in the last couple of hours, the tractor has suddenly stopped running 3 separate times. :eek: Each time, it as if you literally turn off the ignition switch! However, once you turn the key all the way off and restart, it fires right up as if nothing ever happened :cool:
The tractor never spits and/or sputters, and there is absolutely no indication the engine is about to cut off. The fuel level is good, the air cleaner is fine and the fuel is fresh.
Any suggestions???
   / Tractor suddenly shuts off #2
Check your fuel filter, it may have debris blocking the flow so sufficient fuel cannot constantly get through...and when it is starved for fuel it shuts off just long enough for more fuel to seep through so when you restart you are fine until it clogs again. Also maybe a loose wire..could be anywhere.
   / Tractor suddenly shuts off #3
Sudden stops are usually electrical related. If you have something available, fabricate a test light connection from the male elecrical connector post on the fuel solenoid. Place the light where you can see it. When the sudden stop occurs see if the light is out. This will tell you if a fuse is opening or the relay is bad. If the light is on you need to them check the solenoid.
   / Tractor suddenly shuts off #4
X2
Check ignition switch as well.
   / Tractor suddenly shuts off #5
Also any safety interlock switches (like a seat switch) your tractor might have may be getting flaky - or the connections to same.
   / Tractor suddenly shuts off #6
Hi,
The answer may be in the OP's problem description.
"However, once you turn the key all the way off and restart, it fires right up as if nothing ever happened"
When you turn the key and manipulate the switch your resetting the connections inside. I would suspect the ignition switch as being the cause however, this is a tractor, always check the connection points and battery ground as well.
Tom
2001 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2001 INTERNATIONAL...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2020 KUBOTA RTV...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
