Tractor starts then quits immediately
   / Tractor starts then quits immediately #1
BC4
Cartersville, GA.
Mahindra
I have Mahindra 2816 geared.
When I start is it quite immediately. Will not run but a second or two. The air filter looks good and fuel filter looks good. Has plenty of fuel.
Has plenty of fuel in the fuel filter holder. Weather in in 60s so cold weather is not a factor.
Any ideas as to the cause of this and how to fix it?
Bob:confused:
   / Tractor starts then quits immediately #2
Is your fuel shutoff staying active?
   / Tractor starts then quits immediately #3
Not enough information. So it runs a second or two and dies. Can you restart it, and does it then run a second or two and die again, or does it keep running? Or is it not usable at all right now?
This thread reminds me of one of my dumber experiences with a tractor. My new (at that time) Kubota would start, and instantly die, once, sometimes twice, before it would start and keep running. I even asked the dealer about it, and he had no answer. And then one day I finally realized what was causing that little problem. When I turned the key to start it, I'd just let the key slip out from my fingers. And the ignition switch spring was strong enough that it would flip the key all the way back to off.:eek: Needless to say, I felt like an idiot.
   / Tractor starts then quits immediately #4
Quite possibly a fuel shut off relay (solenoid) related problem. Check wiring between the solenoid and the key switch.
2008 Suzuki XL7 SUV (A50324)
2008 Suzuki XL7...
2023 Kubota L2501D 25HP 4WD Utility Loader Tractor (A50322)
2023 Kubota L2501D...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
(250) Safety Traffic Cones (A50121)
(250) Safety...
12" Tooth Bucket (A50774)
12" Tooth Bucket...
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
