Tractor slides off icy trailer
   / Tractor slides off icy trailer #2
He is very lucky to be alive, no ROPS it looked like.
As many times as I have loaded/unloaded my tractor on a trailer it still makes me a little nervous every time.
   / Tractor slides off icy trailer #3
That was a close call.
   / Tractor slides off icy trailer #4
He'll find a little extra to be Thankful for this holiday!
   / Tractor slides off icy trailer #5
Whew..hope he count his blessings.
   / Tractor slides off icy trailer #6
Always load on level ground. Even if you have to drive the tractor a little ways to find some. I went sideways off the ramps a few weeks ago not heading my own advice.
   / Tractor slides off icy trailer #8
Yup trailers suck I the snow, mud or wet. That's the one time that I make damned sure the ROPS is up and the seatbelt is on. Does anybody ever weld those little grab cleats to the ramps? It seems like cheap insurance
   / Tractor slides off icy trailer #9
I drove a couple of hundred hex head screws into our ramps to try and improve the traction. The tires just spun on them..... at least 'I' wont go for a fall when I'm walking down the ramps.
   / Tractor slides off icy trailer #10
I have a friend who many years ago rolled an off road buggy while loading it onto his trailer. He has ever since added a winch to every trailer he has owned and simply uses the winch to load his equipment onto the trailer.
Definitely an option for those with the need to load their equipment when its wet as you have no need for traction on slippery ramps and with a good set up the loading is very controlled and your not even on the machine so if for some unforeseen reason it would get away and roll you would be safely out of the way using the remote for the winch.
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
TEST BID LOT (A50775)
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
