Tractor shopping - Mahindra 2810 vs Kioti CK20 HST
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #11
It's 5 ac. mostly grass with oaks. Good luck on your purchase, let us know what you bought.
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #12
City Boy,
I just got in my first dozen of the 15 series Mahindra's. If you like the CK20 Kioti or the 2015 Mahindra but you think it is a little small, test drive the 2615 or 3015. I've always been a fan of gear or shuttle/gear transmissions...but after driving these hydros, I think I am beginning to see why everyone likes them so much. The 15 series Mahindra is built by Mitsubishi in Japan, so quality isn't even a question.
Best of luck,
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #13
Re: Tractor shopping - Mahindra 2810 vs Kioti CK20
City Boy- I am not familuar with what type of transmission this 2810 has, but a tractor can have a foward & reverse shuttle attached to either a straight gear non syncro, or a syncro. trans
Is the 2810 an India tractor or a componant Korean built? I think the Korean has an Iseki transmission, same as a TYM.
Chuck M.
Well, I missed out on the gear drive 2810. It was sold on Friday. So while I was on the lot, I climbed up on a 2810 HST and rode around for a while. Wow! Dealer quoted a price of $16,200 for tractor, FEL, boxblade, rotary cutter, and toothbar. Compared to $14,300 for the CK20 HST w/same implements. I hate to admit this, but I'm thinking hard about the Mahindra, even though that's a couple grand more than I had planned on spending. Decisions, decisions.
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #15
</font><font color="blue" class="small">( I climbed up on a 2810 HST and rode around for a while. Wow! )</font>
I fell in that trap too. It sure is sweet. Better stay away from it else it'll end up in the back yard /forums/images/graemlins/grin.gif
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #16
if u like the tractor, and the $$$ is not out of your range then go for it. whatever u decide on i will have to give my vote for HST. GOOD LUCK
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #17
City Boy, I know just what your going through, after much comparison among a lot of brands I felt the 2810 was just what I wanted, that is until I drove it vs the 2810HST. What a smooth machine! Check the loader specs if it is Mahindra branded. I think you'll find it a little better than on the gear drive. The hydro unit is a little roomier, with no shift lever, you only lose .5 PTO HP with the hydro. I'm not sure if they all come with R4 tires but two that I compared did & the hydro unit had larger tires than the gear unit, able to hold more fluid which made it extremely stable when I was moving full buckets of crushed stone. Also a wider stance. I also liked the two pedal hydro vs the rocker pedal of some other brands. I think the difference in $ is only about $1000 from gear to hydro. Small change for what you get.
Good luck.
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #18
i went to a dealer that has kioti and mahindra tractors and i drove the hst ck 20 and the mahindra 2015 hst and the mahindra buried
the ck in the power the ck was smoother but your buying a tractor
ill take the power
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #19
i was going to buy a kioti ck 20 until i tried the 2015 hst mahindra
it buried the kioti in power,i also have a nh tc 33 and the mahindra
can almost lift as much as the 33!!!
   / Tractor shopping - Mahindra 2810 vs Kioti CK20 HST #20
What's the rated FEL lift capacity for the Mahindra 2015? Could you explain what you mean...it has more power?
Don
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
