Tractor shifts but doesn't move in high gear
   / Tractor shifts but doesn't move in high gear #11
I wonder if there's a way to get some sort of solvent into the clutch space to possibly clean it - if there's a drain plug, might there be some access above? I know if a motorcycle dry clutch gets oil on it (*ahem* older bmw k-bike) it's pretty much done for but that's also because oil there is from a leaking seal that won't stop without a couple thousand dollar donation to the mechanics
I know of only one access and that is under a mounting plate for the loader on the side of the tractor. Trying to avoid this procedure but might consider it if the operation does not improve to my satisfaction. Thanks for your input.
   / Tractor shifts but doesn't move in high gear #13
The oil soaked clutch isn’t likely to get much better especially with oil likely still leaking on it.
Chemical Containers Tank (A57148)
Chemical...
2018 KOMATSU WA270-8 WHEEL LOADER (A60429)
2018 KOMATSU...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2022 LEEBOY 8520B ASPHALT PAVER (A60429)
2022 LEEBOY 8520B...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
