Tractor Shed Expansion
   / Tractor Shed Expansion #1
TTTTTT
Bancroft , Ontario
Dong Feng 354 (Oct 2008)
Since getting the tractor and many toys for it, I realized I needed more outdoor storage. The plan was to expand what I already had where my boat is stored for the winter. From clearing some land and getting some from my in-laws, I had a enough tall straight cedar logs to do the main framing. Using other bought lumber and ordering metal roof panels, I had what I needed. It didn't take too long with the help of my oldest son. When planning I made sure that each bay was at least 8' high so I could go in and out with the tractor ROPS up. The new bays are about 12' wide so it is relatively easy to maneuver trailers etc. in /out and any other toys. With a few good cross members, there is plenty of upper storage for lumber etc. Believe it or not, it still is not quite enough room once everything is put away, but its close.
Thanks for looking
Dave
Existing Shed/Garage
This was my winter storage for my boat.
The Layout
The Build
The Finished Shed
Nice work!!! Kinda post n beam style.
So, did the township building inspector love your work?
Hi Thanks,
Don't want to open the can of worms, but this job the inspector has not had any input on. I copied it in part off my neighbors. Very functional
Thanks Dave
   / Tractor Shed Expansion #4
Hi Thanks,
Thanks Dave
I can see that.... Whitedogone.... Building Inspector:eek:
   / Tractor Shed Expansion #5
Looks nice and I can understand it not being big enough. Just couple questions. How is the structure attached to the ground? Are there footings? Looks like it is just sitting on top of the concrete.
   / Tractor Shed Expansion #6
Ditto
It is not anchored and is sitting on very solid compacted "A" gravel. The original had not moved for 10 years. You may notice on the finished pic, it is very sheltered from wind by a treed hillside. The posts are set in the 4"x4" deck block pattern, so they aren't just sitting on top. Once all was braced together, it is a very solid structure. Once you have a bay for the tractor, a bay for the boat and a bay for my larger trailer and then implements, it runs out fast.
Dave
   / Tractor Shed Expansion #10
I'd be happy with a tractor shed the size of your origional. I want to get one up before the snow flies. What you're building looks nice.
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
