tractor shakes while running brush hog
   / tractor shakes while running brush hog #1
bcfarmer45
brush creek tn
MF 285
I bought a used almost new tsc brand 4ft bush hog for my MF CG 1715 and it really shakes the tractor a lot I think more than it should. I checked under it all looks and feels ok anyone have this problem?
   / tractor shakes while running brush hog #2
Try greasing the blade pivots. Often if a shredder sits for a while they will rust and the blades will not swing freely.
   / tractor shakes while running brush hog #3
Make sure the driveshaft isn’t bent.
   / tractor shakes while running brush hog #4
If the mower is cutting good and the blades are free turning on the blade bolts, you may have a bent output shaft on the cutter gearbox. Ken Sweet
   / tractor shakes while running brush hog #5
1) Checks the blades to make sure they are not bent.
2) Check the bolts holding the gearbox down.
3) Grease the U-joints and PTO shaft.
4) Check the oil in the gearbox.
   / tractor shakes while running brush hog #6
Is the tail wheel riding on the ground or do you have the whole mower suspended in the air while mowing, which it shouldn't be? If so, that will add a lot of vibration and sway carried back to your tractor.
   / tractor shakes while running brush hog #7
All good advice. I use a 4' JD hog on the back of one of my B2150 Kubota's. If the blades do not swing freely on the blade carrier -- that is the most common reason for severe out of balance shaking. It doesn't take much to get grass or worse yet some twine or other extraneous stuff wound around the bolt holding the blade to the carrier. I have also seen times when I could find no visual reason, yet spraying both blade bolts with WD-40 made most of the vibration go away. As another guy said it is never "quiet" and if held up in the air always shakes a small tractor more than you would like. If it is an old machine the blades may have been ground down when sharpening so much that they significantly differ in weight out at the tips. Good luck with your particular case.
   / tractor shakes while running brush hog #8
I've had MANY times when I've started both the old LX4 and this Frontier RC2048 when they've been out of balance simply because the blades don't shake out right. Usually can fix it by going back to idle and restarting (on the 2025R; needed to be above idle on the 4010). Sometimes, 3 restarts are needed.
One time on the LX4, restarts didn't settle it out. I looked underneath and had blades across each other. Had to pry one of them out of the way.
Ralph
   / tractor shakes while running brush hog #9
Thanks i will try the things yall posted
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
BUSH HOG 35-06 - 6' REAR MOUNTED BLADE SCRAPER (A51243)
BUSH HOG 35-06 -...
JCT SKID STEER QUICK ATTACH AUGER SET (A51243)
JCT SKID STEER...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
TYN T654 TRACTOR (A51243)
TYN T654 TRACTOR...
SET OF HOMEMADE FORKS (A51243)
SET OF HOMEMADE...
