Tractor Seats
/ Tractor Seats #1
bill18163
NW Pennsylvania
Kubota B2710,BX1860,LA3940
Has anyone replaced the original seat that came with your tractor? I have a B2710 and I have had back problems for years. I would like to buy a seat that has more support and some kind of shock absorbing feature in it. Anyone know where I might find a seat like this? Thanks.
/ Tractor Seats #3
I'm kind of experiencing the same thing with my B7100. I don't like the seat and it really doesn't do much to support the back. Although it'll probably take some engineering, I think I'm going to get one of the weight adjustable seats with a higher back and arm rests. Bird is right, you can see several seat options through the Northern Tool site. Most of the seats I was looking at were in the $125 - $150 price range. I've decided to get one from our local TSC store and will probably install it over Thanksgiving. I'll let you know how it works out.
Anyway, check out the Northern Tool and Tractor Supply Co. websites.
Bob Pence
/ Tractor Seats #4
The 2910 has a different seat than the 2710 -- spring shock absorbing. I love it. There should be no reason it couln't be put on a 2710, although you would probably have to move the toolbox.
/ Tractor Seats #5
Glenn,
The seat on the BX2200 has springs but the ride is mighty stiff. You owned one of these for a few days. How different is the seat comfort between the BX2200 and your current tractor? Should I be shopping for a seat upgrade? Or am I SOL (seat out of luck)?
Huck
/ Tractor Seats #6
Huck, all the B series have springs but they don't seem to do much. But the 2910 has a seat that travels up and down about 2 to 3 inches, with a variable tension control that you can adjust for your weight. Sometimes it almost feels pneumatic to me. My direct comparison is to the BX (standard B) seat. On the BX I would constantly bounce up and down with my seat banging up and down on the tractor seat if I went fast, with me sometimes lifting slightly off the seat. Going over the same ground at the same speed with the 2910, it is the seat itself that travels up and down. Occasionally, it will bottom out, which I could probably fix with the tensioner.
Again, it is a big difference. I'm sure there are aftermarket seats from sources such as Bird has posted. Chalkley has one about which he sings rhapsodies.
Glenn
/ Tractor Seats #7
Bob, I see you are considering a seat with high back and armrests. I bought a used tractor with a similar seat installed. For my use, it isn't as comfortable as it appears. There aren't many times when I can settle down in the seat and use the armrests. And they are in the way for the side to side movements necessary to operate a tractor. I took my armrests off because they were in the way.
The high back also interferes with adjusting the top link (manual) from the seat. Also with a low back seat I can maneuver the lower links' connecting rods when hooking up to equipment.
I just wanted you to think it out before you buy something that isn't as useful as you thought.
Gene
/ Tractor Seats #8
Everyone likes things different for different reasons, Gene. I spent a lot of time on a neighbor's old Oliver cutting and baling hay, and I liked the arm rests on the seat. But anytime he uses that same tractor, he folds the arm rests up out of the way; would just as soon not have them on the tractor. My B7100 didn't have arm rests, but now my B2710 does, and I use them all the time and wouldn't want to be without them; never fold them up out of the way./w3tcompact/icons/smile.gif
Bird
/ Tractor Seats #9
You're right , Byrd, like the old saying goes, "Whatever cranks your tractor". I just wanted Bob to have enough information to consider all the angles.
Gene
/ Tractor Seats #10
Check out the thread "L4310 enhancements" in this same section of the board for quite a bit of info and some pictures. I actually just updated it a few minutes ago with some more info on one of the seats Northern sells.
I don't know how the seats attach to the B-series tractors, but there was very little work involved in getting these seats mounted on the L4310 and L2250.
And there's no doubt about it: They will sure take a lot of the pain out of extended tractor use.
MarkC
/ Tractor Seats #11
GeneP, thanks for the thoughts. I spent the first 25+ years of my life working my Dad's dairy farm and spent eeennndddllleeesss hours in the seat of an IH 1456, Ford 9000 & 5000 as well as a few smaller tractors and the occasional week or two in the seat of a combine. The larger tractors all had the weight adjustable seats with higher backs and the IH had arm rests and would even swivel 45 degrees to either side. You could actually get pretty comfortable in the seat of that thing.
You're right about thinking through what type of seat to use as a replacement. In running the larger machines I became hooked on the high back seats simply because extended hours on the machines will take a toll on anyone's back. And since I just saw the big 50 on my last birthday, I find I need the lumbar support and cushioning some of the adjustable high backs provide. As far as the armrests, I was going to get them 'cause I think they'll be cool. No other practical reason.
The B7100 is typical of the smaller Kubotas in that it doesn't provide much in terms of "ride quality" and the seat really doesn't help that situation much. Most of the hours spent on the little beast are mowing, bush hogging, and grading or moving snow. On this tractor, I can reach the top link if I need to, but can't reach the lower link adjuster from the seat. Still have to get off the tractor to reach that. I guess I'm just looking to improve the comfort for my butt and back while in the saddle.
I'll keep you posted on how things work out.
Bob Pence
/ Tractor Seats #12
Look at the seat on any of the M Series. It is a very comfortable seat with arm rests. You can barely reach the top link from the seat anyway, but a hydraulic top link eliminates that problem. The arm rests are really nice and much better than my previous Massey seat that was well sprung but without the arm rests. A good seat is not going to be found for $100, but they are worth what they charge for a good suspension seat.
/ Tractor Seats #13
just thought I would let everyone know how I didn't make out "with the new seat" It sounded soooooo good 4" of travle with a shock, great! well the seat look good it just won't fit. Im sure that it would work just fine for most folks 6' and under, but any taller and your going to trade a better seat for cramped leg room. It was a modle 17492 from northen hyd. and I tryed to put it on a L4610. It just won't go back far enough. Back to the drawing board. Any other ideas out there? Maybe a shock for the stock seat?
Rich
/ Tractor Seats #14
Rich - Sorry it wouldn't work for you. How tall are you, anyway? I'm 6'0", well, I used to be - I'm probably 5'11" by now.
Mine doesn't go back as far as the original was, but it's fine with the steering wheel tilted closer to vertical.
MarkC
/ Tractor Seats #15
Mark, the tractor pulling the cup is GREAT!
/ Tractor Seats #16
Billc - I thought it was highly appropriate. But it never would've happened without Harv making such a big deal of the cup, among other things. /w3tcompact/icons/laugh.gif
MarkC
/ Tractor Seats #17
After seeing the size of the cup hooked to Mark's tractor I tried to calcualte what it would take to lift a cup that size, full. Near as I can cypher, understanding my cyphering skills are somewhat limited, I don't believe Kubota has produced a tractor / loader combination yet that could hoist THAT CUP.
Bob Pence
/ Tractor Seats #18
Bob - Why do you think I'm dragging it? /w3tcompact/icons/laugh.gif
MarkC
/ Tractor Seats #19
Mark- well I thought I was 6'6" but you make a good point maybe only 6'5' now? Any way its to tall thats all I know. Most things don't fit, Im kinda used to it by now.
The up side is the tires work great/w3tcompact/icons/smile.gif It looks like your draging a 55 gal. drum with a handle on it behind your
tractor? do you realy drink that much coffey??
Rich
/ Tractor Seats #20
I finally bought a new seat for the B7100 on Friday nite and my neighbor and I installed it Saturday. It's a suspension seat with 2" to 4" of vertical travel, weight adjustable, high back, and fore/aft adjustment. Although I bought it at the local TSC store, the Northern Tools website has the same basic seat, #17491. I opted for a seat without fold down armrests and went for one that has molded armrest "stubs" that kind of surround your back and inhibit lateral movement. I sat in the seat with armrests and found the one I bought generally more comfortable overall for me, especially the lower back support.
The installation was interesting. I made a 9" x15" plate from 3/4" marine plywood that I mounted (bolted) on the brackets that held the adjustment track for the original seat (I'll probably switch this to a 1/4" steel plate when I get some plate steel). I had to take this approach in order to position the new seat far enough back on the tractor since the front edge of the new seat extended so far in front of it's mounting plate. In fact, the back of the base is mounted against the ROPS posts, although still allowing sufficient room for the suspension system and access to the top link pin. I then bolted the seat adjusting plate to the plywood platform. Not at all difficult, it just took a while to figure out the best way to mount the new seat.
A couple of observations. With the new seat I sit about 1 1/2" - 2" higher than in the original seat. The new seat extends about 2" further into the operator area than the original, even moved as far aft as possible, so some room was compromised. Operator space was initially a concern.
Now, the really great news. The new seat is absolutely, positively, undeniably, and beyond a shadow of a doubt the best $148.39 (plus a few nuts, bolts, washers) that I've spent in a long time. Although it sits slightly higher and a bit of room was compromised, but not enough to really matter, the ride and action of the new seat is at the very least, excellent. My son, who is 6' 3" tried it out and gave it a stamp of approval as well. I'm 6' and found the arrangement to be all I'd hoped it would be. I think I actually like the positioning in relation to the steering wheel better than the original seating position.
Yesterday (Sunday) I spent about 3 hrs. in the afternoon mowing & chopping up leaves before pulling the mower deck off for winter. For the first time since I've owned the B7100 I had two notable experiences: 1) I had support for my lower back while driving. 2) After 3 straight hours in the saddle, I got off the tractor without a stiff back or sore butt. As far as I'm concerned, that seals the deal for me. The only thing that has been adversely affected by the new seat installation is reaching the 4wd lever. It's more difficult now to reach down below the Hi/Lo range lever, but it's not often I switch between 2wd and 4wd, anyway.
My wife thinks the seat looks a bit "big" on the B7100. Maybe it does since the seat is actually designed for larger ag equipment, but it does a nice job on the little Kubota. Frankly, don't care how it looks.
I bought the seat from TSC vs. Northern Tool for a mostly economic reason. Both sold the same basic seat for $139.99. With Northern Tool, adding a shipping charge of $21.68 brought the total to $161.67. At TSC, adding 6% sales tax brought the total to $148.39. And, at TSC I could actually sit in the sample/display seats and see which one fit me the best.
Unlike a lot of folks, I'm somewhat technically challenged and don't have pictures to post, YET. I'm going to borrow a digital camera this weekend and will hopefully have pictures showing the installation next week.
I just wanted all those folks out there considering seat upgrades to know....it can be done with a little thought, ingenuity, and help & advice from your friends. And, it's really worth the $$ and a small time investment in terms of comfort. The only question I've asked myself the past two days is: "Why did you wait so long, dummy?"
Bob Pence
Wolverine RPR-12-72W Skid Steer Ripper  (A62679)
Wolverine...
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
1999 CHEVROLET 3500HD SERVICE TRUCK (A64277)
1999 CHEVROLET...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2007 International 7300 Digger Derrick Crane Truck, VIN # 1HTWBAAN77J422035 (A65563)
2007 International...
