tractor seats too low
   / tractor seats too low #11
I have a "hot pad" - much like the pad D2cat shows. Use it directly on the seat, in the winter. Retains body heat, raises the seat height slightly & provide a bit softer ride. Especially in the winter when the OEM seat is rock hard. Store the pad inside. So it's warm to start with when placed on the tractor seat.
   / tractor seats too low #12
I don't have a problem with height so much as with leg room. My knees always hit the dash when I turn around while backing up, easy to bump the ignition switch to off. May or may not notice it for a while during the day since all it does is turns off the electrical system...can't imagine it's good for the charging circuitry.
I re-drilled the mounting holes and got another inch or so, but could really use more.
I guess like cars from the Orient they're just not made for people with long legs...
   / tractor seats too low #13
I had the same problem with my SCUT, now the same with a small compact. On the scut, I just raised the whole seat assembly using 2" square stock. When I sold the SCUT, the buyer was 6'5" and could operate it OK. On the compact tractor, I put on a new seat that was about 3x thicker, also adding 2" brackets, but only on the front mounts 'tilting' the seat back. Worked out great! I now have much more leg room.
Wow Guys:
thanks for all the great suggestions. i think this is a combination of a little more height and moving the seat back a bit. Will send pics once I get it done.
Kind regards,
carpediem
2014 Ford Escape (A50324)
2014 Ford Escape...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
2014 John Deere 4940 Sprayer (A53485)
2014 John Deere...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
