Tractor rpm problems
   / Tractor rpm problems #1
padme1682
coupeville, washington
New Holland/ TC-18 hydrostatic drive
When using my PTO on my TC-18 it will work for awhile and then start loosing rpm. I disengage the pto and the rpm will go up and down for several minutes and finially stableize at 540 for the pto setting. Off I go and wham it starts again a few minutes later. I have changed all hydraulis fluid and filters, fuel filter, both air filters. The unit has 1680 hrs on it and this problem has been getting worse. Looking for ideas to help. I changed one fuel injector many hours ago. Really thinking this is a fuel problem.
   / Tractor rpm problems #2
Check vent on fuel tank.
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2012 PETERBILT 587 SLEEPER (A54313)
2012 PETERBILT 587...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
