Tractor ran fine, restarted normally, then died & won't start
   / Tractor ran fine, restarted normally, then died & won't start
Called the dealer I bought it from and they suggested checking the seat switch, transmission switches, and PTO switch as well as the fuses.
I'm more of a tractor owner than a tractor mechanic, but I'll take another stab at it tomorrow.
   / Tractor ran fine, restarted normally, then died & won't start #12
Do you get a click when you turn the key on? If not it could be the stop solenoid. No click could signify that the stop solenoid is not functioning. Easy to check, find the stop solenoid, usually on top of the engine (look in owners manual) and you will find a round device with a rod coming out of it, a couple of wires and hooked to some linkage. The key will activate an electric charge which causes the solenoid to push the rod and the linkage out allowing the tractor to start. You can check the solenoid by moving the plunger by hand, very easy to do!
If it is the stop solenoid the tractor should start. To stop the motor reverse the position of the plunger to shut the tractor off.
Found the problem. As the dealer tech suggested, I found a blown 5A fuse.
Thanks for everyone's help!
   / Tractor ran fine, restarted normally, then died & won't start #14
Gotta like when there was quick fix. (y)
Unfortunately the replacement fuse didn't last very long. So, is it likely something is shorting out?
   / Tractor ran fine, restarted normally, then died & won't start #18
A 5A fuse in my tractor protects the engine stop solenoid relay and pre-heat controller. Burning this fuse will certainly stop the engine...
Unfortunately, I haven't found my manual, so I'm not sure. I found schematics here: New Holland Tc30 Wiring Schematic - Style Guru: Fashion, Glitz, Glamour, Style unplugged There are two large jpegs. Not sure how to read them, though. (And that page is a bizarre collection of stuff.)
I did crawl all over looking for wiring issues and I found that the parking brake switch wires were disconnected and dangling. I plugged them back in and it ran OK for a while, and when it died one of the wires was disconnected again. Gonna try taping them up to see if that helps, but not sure why, after all these years, those connections are coming apart now.
   / Tractor ran fine, restarted normally, then died & won't start #20
It doesn't say on the fuse box what the fuses are for???
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
New Holland WorkMaster 37 (A53317)
New Holland...
2014 Electric Cart (A53424)
2014 Electric Cart...
UNKNOWN  UTILITY TRAILER (A55745)
UNKNOWN UTILITY...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
