Tractor rake
   / Tractor rake #1
bennyhill
yanmar 2210b
Has anyone ever welded the forks on a rake? Didn't know if this would be a good thing to do..
They do get loose from time to time, and gets bent.
I just didn't want to lose one or more of the teeth.. I have lost a tooth on the box blade took me hours to find it under the Mud ;,(
   / Tractor rake #2
I'm not sure that is a good idea because
the tines are designed to be replaced if bent or broken
   / Tractor rake #3
Like stated not a good idea, the tines are heat treated and tempered...
To be fair it can be done but the procedure is usually left to certified welders, there is a whole set of preheating, welding with correct filler, temperature and possibly slow cooling or after heat that has to maintained to produce a weld that won't fail or the tine won't fail..
   / Tractor rake #4
Red top is absolutely right. Those are spring steel so they would have to be welded then stress relieved then re-heat treated. Possible but ain't worth the time and effort just buy another one
   / Tractor rake
Had to ask.
Thanks everyone :sneaky:
   / Tractor rake #6
Maybe you should look into attaching them a batter way if there always loose and falling out.
Why are they coming loose?
   / Tractor rake #7
Reassemble with Red Loctite.
J & M 1150 Grain Cart (A50514)
J & M 1150 Grain...
Edco Hand 8" Post Hole Digger (A50774)
Edco Hand 8" Post...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A50323)
2007 Western Star...
20' Sea Container (A50774)
20' Sea Container...
2022 John Deere 6135E (A50120)
2022 John Deere...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
