Tractor quit running. Air in fuel?
/ Tractor quit running. Air in fuel? #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
MF 5465. Initially noticed it had to turn over more before cranking, but didn't think much of it. Didn't get far before it shut down. No power loss or rough running, just shuts down like I turned it off. Idled it up to 1500 RPM's and it shuts down after about 3 minutes. I can manually prime it and it starts again. If it is air getting in system, how would I trace down the leak?
/ Tractor quit running. Air in fuel? #2
Pull fuel line from tank before filter/pump/etc right after it quits....make dang sure you are getting good fuel flow from the tank.
Twice, a bug has gotten in mine, floats around until it blocks the outlet hole, starving the fuel out...floats away again to allow fuel to flow until the next time, and so on. So check that first.
/ Tractor quit running. Air in fuel? #3
Check to be sure tank has good fuel flow out of tank & tank is venting.
/ Tractor quit running. Air in fuel? #4
I have seen a fuel lift pump fail gradually, and the first step was where it would leak enough that the engine would quit, but you could get it started again by using the priming leverl (Perkins engines are know for this problem with that style lift pump).
Could I check to see if fuel filters are full when it shuts down to determine that it is getting adequate fuel from the tank?
/ Tractor quit running. Air in fuel? #6
As above, but I'd also check your coolant level... I recently had my tractor shut down for no apparent reason; oil level fine + good fuel (although I did have to drain the water 'catcher').
I popped the bonnet to check my battery cables and noticed the coolant level was way down. Topped it up and all is well.
Mind you, it is time for an oil change + filtre. I'll change the fuel filtre whilst I'm at it.
/ Tractor quit running. Air in fuel? #7
Yes if you have a clear fuel bowl or inline filter, start it up and then watch the filter.
Fuel should stay at a pretty consistent level.
/ Tractor quit running. Air in fuel? #8
Another possibility is a pin hole in a fuel line between tank and lift pump. They can leak air in under suction of the lift pump but not fuel out. Sounds odd but it can happen.
/ Tractor quit running. Air in fuel? #9
Since nobody asked, did you replace the fuel filters after it quit? If not, that's the first step.
/ Tractor quit running. Air in fuel? #10
Nope....the first step is make sure you actually HAVE fuel at the filter inlet. Otherwise, you could change it and it wouldn't make a lick of difference.
Once you determine there is fuel to the filter, yep....change it.
/ Tractor quit running. Air in fuel? #11
We already know fuel is getting to the filter inlet because he's able to manually prime and restart after it dies.
I plan fuel filter changes any time there's a fuel issue with a diesel. Once you're opening the system up, you might as well change them anyway. When you take the filter(s) off, you should know if you're getting enough fuel to them. Worst case...shut the supply valve/petcock, remove the filters, open the supply valve and see what happens. If the supply seems weak, then I look at the supply from the tank to the filter.
/ Tractor quit running. Air in fuel? #12
Both times I had a tank outlet blockage, I could wait a minute or two, the little electric booster pump would get enough fuel to re-prime the system (equal to a manual priming) and the tractor would start.
The bug in the fuel tank would jiggle off the fuel outlet (I know this because I finally stuck a Rigid inspection camera in the tank and watched it happen), and the tractor would run until the bug floated back over the outlet....shutting off enough fuel to kill the engine.
I changed the fuel filter initially, thinking the same thing. Took it to the dealer, where they replaced the electric fuel solenoid shutoff....twice....and were going for a third time until one of the mechanics noticed the fuel strainer bowl back at the tank was actually sucking INWARD (plastic bowl), and was empty as the main fuel pump tried to get fuel. He jerked the fuel line off the tank, and there was barely a trickle of fuel. Stuck a screwdriver up in the tank outlet, and got hosed with fuel ! That was at 150hrs.
Couple years later at 700hrs, same thing happened again. This time, I knew to look first at the tank outlet. Same thing....engine quit, remove line...tiny fuel flow. Got out the camera, looked in the tank...sure enough...a small wasp (dirt daubber we call them) right over the fuel outlet. Took a long grabber tool, along with the camera, removed it.....everything good again.
How did the wasp get in the tank ? I suspect my fuel fillup hose. I hang the nozzel on a hook pointing up....I think the wasp flew in, died, and when I went to fill up one time, I hosed it in the tank....can't figure any other way (line between fuel tank and nozzle has a 10 micron filter, so it didn't come via the tank) it could get in a closed tank. Only time the fuel cap is off, I'm standing there filling the tank. SO now I dip the nozzle down, bang it against the wall, let a little fuel flow out first before I fill the tank.
This may well NOT be the OP's problem......but having had it happen to me twice, I'm inclined to look at fuel flow FROM THE TANK first dadgum thing now.
/ Tractor quit running. Air in fuel? #13
Doing what I described would have found your insect problem. Close the fuel supply petcock, remove the filter, open the fuel petcock, check for flow before installing the new filter. Many tanks aren't exactly easy to check the fuel outlet, and most folks don't have an inspection camera handy, so they're forced into cracking a line at the filter inlet....at that point you're going to have to purge the system of air anyway, so you might as well replace the filter while you're at it.
I've dealt with fuel delivery problems many times over the years and they've all been either plugged filters, or failed lift pumps....no bugs in the tanks, although I know it can happen.
I plug the end of my fuel nozzle with a rag before I put it back on the tank ;)
I haven't done much with it until this morning. I checked voltage at plug for in-tank pump and read 6v. I'm assuming that's correct because the tractor started. Clear water-in-fuel bowl on filter always stayed full with no indication of air or lack of fuel. Tractor idled for 10 minutes. Went up to 1300 for 10 minutes. 2000 for 10 minutes. I had almost decided whatever the problem was went away, but at wide-open throttle it ran about 5 minutes and shut down. Up until this point the tractor ran great, then shut down just like I switched it off. Temperature was fine. It again restarted after turning over more than normal and manually priming it. I cranked just to see then shut it down. 2 hours later I went back. Manual primer is tight but tractor would not crank as it easily as it should so I went ahead and pumped it a couple times. Cranked up and went to wide-open throttle. It ran 15 minutes and shut down. Temp gauge read normal. Fuel bowl full. Manual primer tight. Tried cranking and it again turned over more than normal without cranking, so I quit since the problem seemed to be the same.
Just went back and opened fuel cap, primed, and again it's not starting.
A quick look at my operator manual says it has a mechanical lift pump so the 6v must have been for the fuel gauge
/ Tractor quit running. Air in fuel? #17
I went through something like what TnAndy described, but my ZD25 mower didn't cut off most of the time, it just lost power in a big way and most of the time I could idle just fine, but WOT was a no go. I pulled fuel lines and verified flow, changed filters and could not find the problem, until I pulled the tank and found some alien globs of goo hanging around in the bottom of the tank. They'd get sucked into the pickup tube slow or cut off fuel flow but after letting the mower sit for a few minutes they'd drop out and float around a while longer until they found their way back into the pickup tube.
I'd pull the tank unless you can drain it and look inside with a camera. You have received good advice in this thread. Go though it step by step and you'll find the problem.
Chris
/ Tractor quit running. Air in fuel? #18
Not to be too blunt, but people have offered advice, and asked you questions, but it doesn't appear you've answered them, or attempted any of the diagnostics suggested. Are you looking for help, or to just report what you're experiencing?
From the description of what's happening, it's likely a classic case of the lift pump failing. The pump has I've seen the exact symptoms happen four times now on Perkins engines with the same style lift pump. Looks like this:
MASSEY FERGUSON FUEL LIFT PUMP 4222449M91 422476M91 4225162M1 - GD FUEL LIFT PUMP LTD.
I have good fuel flow, as suggested. Tank is venting, as suggested. Blockage in tank, haven't checked. Fuel filters, haven't changed. I haven't been into town where I could purchase any.
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
