Tractor problem
   / Tractor problem #1
Fergieman
Maccormick cx95
My maccormick cx95 starts and then stops after a couple of seconds. It might take six or seven tries to get it started again after which it runs perfect . Its a 2003 model with a perkins engine. Any help would be appreciated
   / Tractor problem #2
I looked it up, looks like made in UK, Perkins diesel. I would start with basic things...I assume it has glow plugs? If so check them and that circuit. Then have you changed filters? Sounds like glow plug problem or not getting fuel.
   / Tractor problem #3
A diesel in reasonable mechanical condition needs a good battery/starter combination and adequate fuel delivery to start. Does your tractor have both?
   / Tractor problem #4
If it starts & stops several times before it stays running, you have a supply problem.. is it gravity fed or does it have a lift pump?
If it has a lift pump, try to clean it.. a lot of them can come apart & have a filter inside..
Check to see if its actually working.. if not replace it.
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A52472)
2021 ALLMAND BROS...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2019 FORD F-250 SUPER DUTY (A52472)
2019 FORD F-250...
