Tractor Problem (help!)
   / Tractor Problem (help!) #11
I once ran into a problem with "bad" diesel once a few winters ago...turns out it was unleaded gas. I was at work during a snow storm, and had been moving snow with our L2850 all night. I went into the shop around 5am after the tractor had been running all night, and after a small break filled the tractor with "diesel" and headed back out. There was enough diesel in the tank that the gas didn't start to really affect anything for about 40 min, then I started loosing FEL power and the tractor would stall like under a heavy load. I ended up getting pulled back to the shop by our backhoe, and after the tractor sat for a few days over a holiday weekend, the mechanic drained the tank and changed the filters and she started right up. He told me that gas burns hotter than diesel, and after 40 min or so, the whole block had heated up and essentually locked up. After cooling down, it was fine.
When I had filled it with "diesel," I had actually grabbed the gas hose. I blame it on the early morning hours, that I hadn't filled anything up at those tanks in months, and the tank lables were covered in snow. All of our tractors have been filled with gas several times before by just about everyone on the crew, although it is usually caught before they head out. Look for the foam in the tank: diesel foams a lot more than gas.
   / Tractor Problem (help!) #12
You have bad fuel or dirty filter or clog air filter. check and replace.
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A58018)
2020 FREIGHTLINER...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
(INOP) CHEVROLET C-50 GRAIN TRUCK (A52708)
(INOP) CHEVROLET...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Mini-Excavator Heavy Duty Grapple Attachment (New/Unused) (A59225)
Mini-Excavator...
