Tractor Power
   / Tractor Power #1
olatiwa
gaborone, botswana
john deere
how do you calculate the tractor power required for 100 hactors of land?
   / Tractor Power #2
Tractor size is generally determined by implement size. The bigger the implement, the bigger the tractor and the more ground you can work at a time.
Aaron Z
   / Tractor Power #3
Do you mean the size of a tractor in Horse Power that would be usually used for that amount of acreage or the amount of fuel in gasoline or diesel to cultivate that amount of land?
   / Tractor Power #7
100 hectares is 247 acres. Pretty big area.
1st, figure out the task e.g. no-till grain drill.
2nd how many hours are available to perform the task?
3rd, calculate hectares/hr required. If you want to plant 100 hecatres in 16 hours, you need to plant at a rate of 100/16= 6.25 hectares per hour (ha/hr).
4th, look up some available implements and how fast they can be used. 1 hectare = 10,000 sq. meters. An implement 1m wide traveling 1km/hr will cover 1000 sq. meters per hour or 0.1ha/hr.
If the implement is 6m wide and traveling at 10km/hr it will cover 0.1x6x10 = 6.0 ha/hr. Pretty close to the example target. It will complete the task in 100/6 = 16hr:40min.
Finally, contact the implement manufacturer and ask about recommended horsepower. You can repeat for various predicted tasks and figure out which one requires the most power.
   / Tractor Power #8
And don't forget the soil type can affect requirements too. Light fluffy soil runs faster than heavy clay.
   / Tractor Power #9
For just a wild guess I would think you are needing somewhere in the neighborhood of 75 horsepower. Some may say this is too low or too high but it is a starting point.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
1989 14ft. Gamefisher Aluminum Jon Boat with Trailer (A51694)
1989 14ft...
CAT 973 (A47384)
CAT 973 (A47384)
2013 INTERNATIONAL REEFER TRUCK (A53426)
2013 INTERNATIONAL...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
