Tractor Power
/ Tractor Power #2
Tractor size is generally determined by implement size. The bigger the implement, the bigger the tractor and the more ground you can work at a time.
Aaron Z
/ Tractor Power #3
Do you mean the size of a tractor in Horse Power that would be usually used for that amount of acreage or the amount of fuel in gasoline or diesel to cultivate that amount of land?
/ Tractor Power #7
100 hectares is 247 acres. Pretty big area.
1st, figure out the task e.g. no-till grain drill.
2nd how many hours are available to perform the task?
3rd, calculate hectares/hr required. If you want to plant 100 hecatres in 16 hours, you need to plant at a rate of 100/16= 6.25 hectares per hour (ha/hr).
4th, look up some available implements and how fast they can be used. 1 hectare = 10,000 sq. meters. An implement 1m wide traveling 1km/hr will cover 1000 sq. meters per hour or 0.1ha/hr.
If the implement is 6m wide and traveling at 10km/hr it will cover 0.1x6x10 = 6.0 ha/hr. Pretty close to the example target. It will complete the task in 100/6 = 16hr:40min.
Finally, contact the implement manufacturer and ask about recommended horsepower. You can repeat for various predicted tasks and figure out which one requires the most power.
/ Tractor Power #8
And don't forget the soil type can affect requirements too. Light fluffy soil runs faster than heavy clay.
/ Tractor Power #9
For just a wild guess I would think you are needing somewhere in the neighborhood of 75 horsepower. Some may say this is too low or too high but it is a starting point.
Deutz DX140 Tractor (A66285)
Deutz DX140...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2023 Big Tex 16GN 102''x40' Gooseneck Trailer (A64127)
2023 Big Tex 16GN...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
12' x 76" Tilt Trailer (A66285)
12' x 76" Tilt...
