Tractor power using disc mowers
   / Tractor power using disc mowers #1
pvcman1
bridge lake bc
mccormack international434
Hi,was looking at buying a disc mower untill i found out it recomended a min of a 50hp tractor mine been 43hp.would 7hp make alot of difference?,it would be cutting 4 foot tall grass on flat land.Thanks.:confused:
   / Tractor power using disc mowers #2
A drum mower would work.
   / Tractor power using disc mowers #4
They rate equipment for a reason , it would be good if you could try one out to see . It may mean you would only have to go a little slower then a tractor with more HP. .A dealer might give you some good info. also from their experience with that piece of equipment .
   / Tractor power using disc mowers #5
you can get a 6ft disc mower that should workk on your tractor.now in tall thick grass you may have to cut in low 2 with the rpms at 2000 or a tad higher.
   / Tractor power using disc mowers #6
Starting a disc mower is hard. I use a 9 1/2 foot pull type MoCo and you do notice starting it and any incline makes the tractor work. I mow at 6 mph with a 95 hp tractor.
One more note on disc mowers, I haven't looked at the specs in a while. At one time Deere under the rated HP recommeneded x HP + cab. About once a year the cab takes a hit from rocks, usually from hitting a woodchuck mound hidden in the grass. I know other members here have said that they have even had windows broken.
I wouldn't mow without either a cab, or maybe a sheet of polycarbonate between me and the mower. Possible with a 3 point mounted machine any rocks would end up going either forward to the tire would block them. I would still not want to run one with an open tractor.
Here is another thread on disc mowers and the very 1st post brings up that the some OEM's want a cab tractor.
http://www.tractorbynet.com/forums/attachments/75746-questions-disk-mowers.html
Yes I have a complete curtain on the front of the machine and all guards in place. Rocks still find their way out of the machine.
   / Tractor power using disc mowers #7
   / Tractor power using disc mowers #8
My rule of thumb is 7 pto horsepower for each head on flat ground. It takes a bit to get one going, even my 100 pto tractor balks a bit on startup (blows a little smoke). Always a cab tractor. an open station is an invitation to get hit by tocks, wood or whatever that the discs throw forward.
I actually have 2 mowers, a sickle bar conditioner and a disc bine. I use the sickle on fields that I'm not sure of whats under the hay (like a new customer). I never run the disc machine on new fields.
Typically, I can mow twice as fast with a disc compared to a sickle and plugging in tall, damp forage isn't an issue, however, the sickle produces a better close cut on 2nd and 3rd cuts versus the disc.
If fuel is an issue, always run a sickle. Disc machines suck fuel, much like round balers versus small square bailers.
Finally, if in doubt about any poly twine left in a field (from missed bales, run a sickle. Poly twine is a quick death for the upper seals on a disc machine.
   / Tractor power using disc mowers #9
Find a disk mower rated for 40 PTO, 5 disk gear drive or 6 disk shaft drive.
I would want full power for 4 foot high grass. I run 5 disk gear drive on 42 PTO HP, I have to drop a gear in the stuff that is thick and taller than the 14.9-28 rear tires... Tractor plays with it otherwise and I am sure it would run 6 disk gear drive in most of my cutting.
2003 CATERPILLAR 963C DOZER (A43004)
2003 CATERPILLAR...
2014 LOAD TRAIL GOOSENECK TRAILER (A45046)
2014 LOAD TRAIL...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A44391)
2019 Ford F-550...
2011 John Deere HPX Gator 4x4 Utility Cart (A44572)
2011 John Deere...
2012 PETERBILT 388 DAY CAB (A45046)
2012 PETERBILT 388...
2020 Ram 1500 Classic Crew Cab Pickup Truck (A42744)
2020 Ram 1500...
