Tractor Position on Trailer ??
   / Tractor Position on Trailer ?? #11
Scrounger,
On my old Expedition you could turn off the load leveling suspension. If the Yukon has that feature you could turn it off while loading and use the check then turn it back on.
I use a similar method of what was posted above except I use my adjustable height roller supports (used for my miter saw and table saw to suppor wood). I adjust one so that it is level with the bumper. Then I step up on the bumper and see how far it goes down. That is my mark to eye when I load the BX. I way 215 pounds the BX is ~2000 with loader and accesories so that is 10% give or take. It has worked well in the past.
Just typing this I thought of another quick measurement way. You could take a 2x4 and add a base so it would stand up. Use a tape measure to mark 1" marks staring at the top and then use it as described to measure how far your bumper goes down and it's cheap!!! /forums/images/graemlins/grin.gif
Of course for you Scrounger this only works if you can turn off your auto leveling.
Nice thing about this method is it's quick and easy.
   / Tractor Position on Trailer ?? #12
Unfortunately, the XL wont let you turn off the load leveling air suspension. I just pull the tractor forward and dont think about the tongue weight at all. Our bathroom scale goes to 300# so I guess I could use it too.
   / Tractor Position on Trailer ?? #13
There is a method which uses only one bathroom scale and a brick, plus 2 pieces of pipe and a wooden beam. The heavier the tongue weight, the more you need to space apart the scale and the brick.
Roadmaster has a good description of the method, and diagram of set-up {HERE}
Soundguy....
It's tandem with hydraulic brakes on the tongue (U-Haul)
Eric
   / Tractor Position on Trailer ?? #15
Thanks Rick,
I've been running that very question over in my mind. I want 500 lbs on my hitch when I do get the trailer. Now I know how. Good tip!
   / Tractor Position on Trailer ?? #16
</font><font color="blue" class="small">( Unfortunately, the XL wont let you turn off the load leveling air suspension. I just pull the tractor forward and dont think about the tongue weight at all. Our bathroom scale goes to 300# so I guess I could use it too. )</font>
Load it with the engine turned off. The compressor doesn't run, Rick's trick works.
   / Tractor Position on Trailer ?? #17
It it was like the ford system.. you could also pull the controler fuse.. etc.
Soundguy
ALLIGATOR CONCRETE STATUE (A58374)
ALLIGATOR CONCRETE...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
KBH 25T Tender (A56438)
KBH 25T Tender...
2024 Yakta YXR710 Zero Turn Lawnmower (A57453)
2024 Yakta YXR710...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
