tractor operating environment
   / tractor operating environment #1
unclehan
When you guys use a tractor to do work, most of the time the engine is running at its full power? So this means if the work doesn't have a lot of load, you guys go very fast. And if the work is high load, like plowing, then you guys go slow? But either way, the engine is pretty much in full power most of the time? Is that right?
And an advantage of an IVT or Hydrostatic transmission is that it'll allow good PTO speed control when ground speed is varying such as a hill or change of terrain? Is that it?
   / tractor operating environment #2
95% of my tractor work is not at full power. Most of the time probably at half throttle. Speed is governed by the gear range and the hydrostatic forward reverse pedals. Most of my work (90%) is in mid range. I don't use my CUT for 'plowing' fields, but do us it for plowing snow.
You have the right idea on the advantage of PTO speed vs. ground speed, and hydrostatic plays a big part in that flexibility.
   / tractor operating environment #3
The only time I am any where near full power is when I'm mowing with my MMM. I am barely above idle when using the phd. I don't do any plowing & I don't have a tiller, so someone else might help you there.
   / tractor operating environment #4
I have a 2 cylinder and usually run it around 1400-1600 RPM's doing FEL work. PHD I run it at 900 RPM's. I don't think I ever had it up to 2200 Rpm's since I owned it. Maybe I should but I haven't found the need to. I pulled discs, pulled middle busters ran the PHD and I just use it as I feel comfortable. Pics on me website.
http://users.adelphia.net/~gizmo/
   / tractor operating environment #5
I posted this back in July of 2003. It applies to my tractor. I still haven't gotten many responses as to what other operator's manuals state. It was in a hydro VS gear thread, hence the disclaimer at the start. /forums/images/graemlins/tongue.gif
<font color="purple">DISCLAIMER: I'm not trying to beat a dead horse here, just provide some information for all of us to share. If anyone has something similar in their owner's manuals, please provide it as I'm just curious by nature as to other machines and such. I really enjoy learning new things. Thanks.
Here's what it says in my operator's manual:
This is for a late '70s International Harvestor 2500B. It is a 50PTO HP 4 cylinder gas engine tractor/loader with HST. Some came with backhoes, mine came with a 3PT hitch with draft and position control and independant PTO.
This is from page 22 if you care to read along, if you have the book, of course .
"Greatest efficiency of entire tractor, loader, and backhoe is at 2000 engine RPM and up, depending on desired speed of tools... the tractor forward and reverse travel speeds are controlled by range movement of the foot pedals or the Remote Drive Control Lever.
When pedal is not depressed, the transmission is in a locked or braked position.
Maximum torque and slowest travel speed is obtained with the least downward movement of the pedal.
Example: The least possible depression of the pedals will give you the slowest speed with the greatest torque to the drive wheels for digging or crowding into the stock pile or bank.
Using the tractor brakes is rarely required because:
As your foot moves upward from the hydrostatic pedal you are automatically decelerating your travel speed... and when your foot moves completely off the pedal, the pedal returns to the neutral or lock-up position and automatically brakes your transmission and travel."
It goes on on the next page to read:
"The hydrostatic transmission is designed so that: In high range the travel speed deceleration is less abrupt(slower) and the braking is more cushioned to prevent abrupt automatic braking."
"The cushioned braking and travel speed deceleration is timed with the automatic pedal return(or full-up position)
This definite time differential is designed into the system to not only provide the travel speed deceleration and cushioned stop but prevents accidental reversal of direction by the operator."
This is the part about the engine providing control at all times, which would include braking.
"The operator accustomed to mechanical or torque converter equipped tractor may be in the habit of reducing the engine speed for more positive control when operating in close quarters. This is neither necessary nor desirable with the hydrostatic tractor because the higher engine RPM will provide more positive control of not only the hydraulic tools but also the travel speed and automatic deceleration and braking. Maximum performance and control is achieved with high engine speed."
So, this is where I got my impression that the HST should be run at higher RPMS most of the time. Hope this helps </font>
What is nice about the HST is that you can run at PTO RMP and vary the ground speed infinitely without the PTO RPM changing. Sometimes on a gear tractor, it is hard to find just the right combination of gear to keep the engine at RPM speed for the ground speed that you desire. Not often, but sometimes.
   / tractor operating environment #7
Same here. When back blading some gravel yesterday I was around 14-1600 rpms in mid-range, when I went to use the loader I just dropped it into low rather than bumping the throttle up. It makes listening to the radio easier /forums/images/graemlins/grin.gif
I use just enough power to get the job done or recommended PTO speed and when I plow snow I'm usually moving quickly to throw the snow further, so I apply more throttle so I can step on the HST pedal more.
   / tractor operating environment #8
I'm new to this one so I'm not sure where I'll end up rpm wise once I'm user to it. Been running about 1300 for ripping and tearing with the FEL, abot 1200 for running the plow trying to rip up nasty, boney bank run. Transporting the load is more like 1800 but I go with the foot pedal and dont pay a lot of attention to the RPMs.
I think it might help if the manufacturers states the engine's most efficient rpm - the best power/fuel burn ratio.
Then, all the farmers have to do is to run it at that rpm all the time. And if you have a hydro it'll allow you to finish the work in the least amount of time for the amount of fuel burned.
   / tractor operating environment #10
They do rate the most efficient RPM. It's the torque peak. If there is a published torque curve for your engine, or published torque peak RPM, that's the engine speed which does the most work with the least amount of fuel. Torque peak always signifies maximum mean effective pressure (MEP), which is basically the dynamic cylinder pressure generated during combustion. Typically, the maximum MEP and torque peak are also around where peak engine vacuum occurs while the engine is at steady state load, but honestly, I'm not sure diesel's make any vacuum since they don't have a throttle body. I don't know too much about the diesel cycle, I've only worked on gas engines.
Tafe 45DI (A50123)
Tafe 45DI (A50123)
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A51692)
2004 Pierce Tilt...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2025 K2215 UNUSED Portable Restroom and Shower (A53117)
2025 K2215 UNUSED...
1995 Vermeer 935 Towable Brush Chipper (A51691)
1995 Vermeer 935...
1273 (A50490)
1273 (A50490)
