Tractor not stopping
/ Tractor not stopping #1
yanmars
I have a Mahindra 4510. Just recently when I want to stop the engine it will not, I have to pull the Stop T handle to get it to turn off. Any thoughts, it is really not a problem doing that but rather it worked the way it used to.
Just a comment, a mouse could have been in the dash area as I saw shredded paper etc. I could try to take loose screws to check behind but I have a fan mounted etc. and it would be a bit of a hassle.
Hoping someone has experienced this or has some idea about the same.
/ Tractor not stopping #3
Fuel solenoid is the place to look. Either electrical circuit open or solenoid coil burned out. There is probably a relay in that circuit. Tracing wiring is enhanced and expedited when you have the shop manual and wiring diagrams.
Ron
This is an older post but Tractor Seabee was correct in part. Needed the solenoid coil plus mouse wiring damage.
