Oil & Fuel Tractor not starting after changing fluids
   / Tractor not starting after changing fluids #1
smithdenny
spencer, tn
kioti dx55
Today I changed the fluids and filters on a DK5510 for the first time. I had warmed up the engine beforehand. Now, the unit will not crank, the starter will not engage. Battery is charged. Seems to act as if there may be a safety switch that is preventing if from starting. All indicator lights on dash seem to be operational, but simply nothing when the switch is in the cranking position. What am I overlooking? Thanks in advance for any ideas.
   / Tractor not starting after changing fluids #2
Check the position of all levers, seat switch, PTO, and the treadle that moves the tractor.
Thanks for your suggestions HillStreet. Those are some of the items I suspected might be the problem. It may have been simply the battery was not charged as well as I thought. I connected a charger to the battery to make sure it was charged, tried the engine after the input was down to about 1 amp still with no response. However I left the charger on overnight and this morning it started right up. Still not sure it wasn't a safety switch somewhere, or embarrassingly I can not read a volt meter!
Update: I just remembered before starting the tractor this morning I did manually depress the positioning switch on the clutch pedal. This tractor definitely will not start without depressing the clutch so I am going with that as the possible cause instead of admitting low battery possibility! <grin>
   / Tractor not starting after changing fluids #5
You got it!!! My CK30 wouldn't crank if the clutch isn't pushed in. It's a safety feature so that you don't run over yourself(if standing beside tractor to start it). Dutchy
   / Tractor not starting after changing fluids #6
We all (probably) did this at some time. The variable is how long it took to figure it out.
   / Tractor not starting after changing fluids #7
Thank you for posting what it was, unlike many post problem but not fix!
20306 (A51694)
20306 (A51694)
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
Pickup Instructions (A47384)
Pickup...
