tractor mounted log splitter
/ tractor mounted log splitter #1
MDSteve
Clements MD
Kubota 3710
I was just looking at log splitters the other day and wondered how much a vertical splitter would be? There is no way that I can lift these logs to get them on a horizontal splitter. I just don't want to have another engine to keep up over the years.
Thanks,
Steve
/ tractor mounted log splitter #2
I just saw one at TSC yesterday, $549 with every thing but the hoses to connect it to your tractor hydraulics. It could be used in the vertical or horizontal posistion.
thanks, I will have to check that one out. It sure beats the 1000 bucks for the other one I was looking at.
/ tractor mounted log splitter #4
you might want to consider getting a PTO pump to run the log splitter from. The tractors hydrolics can run it but it will be slower.
/ tractor mounted log splitter #5
That will depend on your tractors hydraulic flow rate. If you have a high enough flow rate, it will operate fine.
/ tractor mounted log splitter #6
Steve--
I have the TSC three-point splitter, and it works fine. It can be changed from horizontal to vertical splitting in a couple of seconds. I was unsure about getting it because a lot of folks had talked about the tractor-driven splitters being slow, but this one splits plenty fast for my needs. The $549 price sounds high, though--I think I paid $499 in December. There have been several threads on this topic, so you might run a search and find some more information.
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Gravely Promaster 350 Zero Turn Mower (A66408)
Gravely Promaster...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
Farmhand CG 3000 Tub Grinder / Bale Processor (A66408)
Farmhand CG 3000...
2022 EZ-GO ELITE...
