Tractor Maintenance
   / Tractor Maintenance #1
freddiepez
Aurora, OH
New Holland 30HP
I have a NH TC 30. Bought it used but in great shape with only 600 hours. Time to change the oil. Can I use "motor oil", or do I need to use a special oil for diesel engines?
   / Tractor Maintenance #2
Welcome to TBN.
Ideally you would use a high quality synthetic or semi-synthetic DIESEL oil rated to the tractor's specs for grade.
Mobil one diesel, Amsoil diesel, etc.
   / Tractor Maintenance #3
I've been using Rotella-T Triple Protection in my TC40. Shell Rotella® Products - Shell Rotella
Never tried the synthetics such as the Rotella T5 or T6, but they should be as good or better.
Rotella T is available everywhere, including Walmart.
   / Tractor Maintenance #4
You need C rated oil, not sure what API rating there up to now CG?? But yes its a diesel rated oil, use what ever rated oil the manual says like 15w-40 or 10-40 or what ever. MOst use Mobile delvac, dello, rotella T, or some syn oil.
Diesel oil is different, it is formulated to hold ash and soot in it in suspension.
   / Tractor Maintenance #5
Oh if you post In the oil and lube forum its a better place for it.
2430 (A51248)
2430 (A51248)
Deer Gates (A53424)
Deer Gates (A53424)
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
Harrell 3605 (A50123)
