Sportsman762
Platinum Member
- Joined
- Mar 28, 2008
- Messages
- 941
It looks like the cylinders are scored and have rust. I would also suspect that the cylinders will need repacked. All the hoses will need replaced. I do not see the front pump that should be on the tractor to power the loader and the backhoe. It might be on the loader.
I would make sure that the hydraulic valves for the backhoe and loader move freely.
Hydraulic valves are expensive.
The hydraulic lines are not cheap either.
This is not a cheap way to get a backhoe. However if you want a project then this would be a good one. It looks solid.
