tractor hydrolics vs hydrolic pump n tank
/ tractor hydrolics vs hydrolic pump n tank #1
kw1
West virginia
Kubota L4400
I am currently using my tractor hydrolics and was wondering if I would get more power out of using a pto driven system with a tank and hydrolic pump. Is there anyone out there who would know about this
/ tractor hydrolics vs hydrolic pump n tank #3
What are you using the tractor hydraulics for? A backhoe? Or maybe something else?
/ tractor hydrolics vs hydrolic pump n tank #4
I am using a backhoe and am currently attaching the hydrolic lines to the tractor. I know that there are independant hydrolic systems for the backhoe but will I get more power out of it.
/ tractor hydrolics vs hydrolic pump n tank #7
An external pump & tank will give more speed (more oil volume being pumped) but not more digging force. Tractor internal hydraulics are set at about 2000 psi. A standard external system will be set about the same. That's not to say you couldn't bugger with it and raise the pressure a little - but there won't be a major difference. The safest way to get more digging force is with bigger cylinders (different backhoe). /forums/images/graemlins/frown.gif
/ tractor hydrolics vs hydrolic pump n tank #8
thank you very much
thank you very much
/ tractor hydrolics vs hydrolic pump n tank #11
I put Hydraulic resevior on front with an 8 GPM pump mounted on the midshaft, because I don't have MMM. The pump is rated for same speed as the mid PTO shaft speed. With this I run my extra hydraulic cylinders with. I still use the hydraulics from the original pump for my FEL and BH. Be patient, you don't have an $80,000 backhoe. It will do anything a big tractor will do, it just takes longer....
/ tractor hydrolics vs hydrolic pump n tank #12
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2020 John Deere 8R280 (A64119)
2020 John Deere...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
2006 Honda Odyssey Van (A61574)
2006 Honda Odyssey...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
STORAGE FEES (A59911)
