Tractor hydraulic/trans fluid
   / Tractor hydraulic/trans fluid #21
I did a test with JD oil (in archives somewhere) and SUDT in my B7800 and the SUDT made the tractor sound quieter, shift smoother and not "lurch" when you first hit the pedal.
JD oil goes in all my machinery except for the B7800 hydrostat.
Maybe hydrostat. trans. are more sensitive than standard gear tractors, at least I would assume so, ether way, I think if I had a Kubota hydrostat. and SUDT oil made it shift better, I'd stick with that.
   / Tractor hydraulic/trans fluid #22
That's what I decided. When I changed at one interval I used the Deere oil and noticed increased gear whine and other issues. It's been a while and I forget but I wasn't happy. I left it in but researched it on the TBN and on the next change went with SUDT. The price really bothered me but there was a noticeable difference in performance.
I figure the SUDT is full or part synthetic and suspect any good synthetic oil would give results similar to SUDT but I haven't gotten that far yet. Synthetic oil of all types does seem to be the wave of the future.
   / Tractor hydraulic/trans fluid #23
Hydros are in general much more sensitive to the oil used than gear type transmissions. Not sure about the other brands but my Kubota hydro has a hydraulic filter that filters the transmission oil which is also the hydraulic oil, but before that same oil enters the hydrostatic transmission it is filtered through a finer, much more expensive filter to make sure the oil with bits of gear teeth, clutch pack material, and other stray particles don't get to the piston pumps and motors which demand much cleaner oil. There is an oil film between all of these moving parts and any particle thicker than this film will cause wear. Hotter oil reduces the film thickness so coolers enter the equation. John Deere provides a lower viscosity oil for their hydro tractors and states it is recommended for use in other companies hydros. The information I have states not to use regular JD20 in their hydro tractors. Prior to Super UDT-2 I had a paper published by Kubota showing how their then plain Super UDT was superior to plain UDT. I haven't seen an equivalent on Super UDT2, as I recall the differences were primarily in cold flow and reduced wet brake/clutch chatter. My M135GX is not a hydro but it has a lot of wet clutches and brakes. I am sure Amzoil makes a synthetic that would prove equal too or better than Super UDT2, but how to know for sure? Somebody recently pointed out you can find the specs for Super UDT-2 online. I found them and saw that the viscosity at 100C was lower than previous Super UDT and also below what one of our hydro transmission suppliers recommends as the limit. Problem for me is this hydro supplier told me they provide hydro transmissions for at least some Kubota equipment. Except for its higher than desired low end viscosity, I would use Valvoline UltraMax Drive Train Oil.
   / Tractor hydraulic/trans fluid #24
In my Kubota I use these off the shelf items...
Hydraulics - Amsol
Engine - Mobil
Filters - Kubota
Because I find the prices reasonable
   / Tractor hydraulic/trans fluid #25
funny enough.. i find CNH filters similarly or better priced than many aftermarkets.
   / Tractor hydraulic/trans fluid #26
I find that john deere filters are often priced lower than aftermarket brands.
   / Tractor hydraulic/trans fluid #27
Yes they are and I think they are of excellent quality. I don't know why so many guys search for off brands when they can get the real McCoy for less money.
   / Tractor hydraulic/trans fluid #28
My L3400DT has 702 hrs. so far, and I just changed trans. fluid this past weekend, had 300 hrs. on it since the last change with TSC the fluid. The first couple times I changed fluid, I had a few specs. of metal on the filter magnet, but this time there was none, just a oily film, I was a little nervous after I had the, a lot cheaper TSC Travellers trans. 10w20 fluid in it for the first time. I almost put the same brand back in, but at TSC store they had Rottela trans fluid and its a 10w30. I wanted to see if my tractor would shift a little better with the heavier fluid in it, and if it doesn't, I'll go back to Travellers fluid next time at the 3 or 400 hr. change.
   / Tractor hydraulic/trans fluid #29
The thinner fluid of SUDT shifted better in my B7800. I switched back to SUDT after trying Deere fluid. Seems that I read somewhere that SUDT and SUDT II were either partially or fully synthetic.
   / Tractor hydraulic/trans fluid #30
Walmarts around here do not seem to carry the Rotella tranny fluid or at least that is what the Walmart sight is saying. If you don't mind me asking, what do they get for it around your way?
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
Unused Delta Crash...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
