Tractor hydraulic pump whine noise??
   / Tractor hydraulic pump whine noise?? #31
My opinion is switch to a full synthetic oil, like Triax UTTO Supreme. This will probably eliminate any viscosity problems in cold weather and resist aeration of the fluid. I am also a fan of putting bigger filters on with similar or better specs if you can find one.
Zombie thread alert.
HOWEVER, if ChuluTrac hadn't posted, I wouldn't have ever read this thread and learned that (at last sometimes) hyd filters can cause a whining noise. Another TBN factoid gem.
   / Tractor hydraulic pump whine noise?? #32
Curious where you found the micron filtration levels of the NAPA filters. I mean, that kind of matters. Aside from them just screwing on.
And generally speaking OEMS won't disclose what filter specs they used for obvious reasons.
   / Tractor hydraulic pump whine noise?? #33
Wix makes Napa filters check wix website for the equivalent Napa filter usually only one number difference, it'll show you the filtering specs.
A hydraulic filter will never restrict fluid flow as there's always a built-in pressure bypass if there is a restriction the bypass will open and allow unfiltered fluid through the filter
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2021 Chevrolet Tahoe SUV (A56859)
2021 Chevrolet...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
HAY SPREADER (A58214)
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
