Tractor has new Baby
   / Tractor has new Baby #1
philbuilt
Maine
1260 Massey/retired. Mahindra 2555 cab TLB
Hi All,
Today without the intent of buying a backhoe for the 1260 I happen to see a new Taylor-way 766 on the side of the road.
I stopped in only to get an out the door price of $3500.00 Tax inc.
It is now mounted to the 1260. I don't like the 3 Point setup and would like to know if someone would have pics of a subframe mount for my 1260.
I did test the unit and find it to be strong but I don't want to hurt the tractor.
Thanks
Phil
Ok, I built a subframe and this bh works great. Its strong and will do everything that I will ask. Comparing to other brand this BH is also well built. It has it's own pto pump that is included in the price no add on. 6.5' @$539.00
My Massey Dealer wanted $1000.00 a FT Plus subframe and install. Anyone looking for a reasonable new BH should try one.
Phil
   / Tractor has new Baby #3
What are the advantages/disadvantages of a BH with a PTO pump as opposed to getting rear remotes and using the tractor's hydraulics? I have wondered about that since I don't have rear remotes on mine. What's better?
Hi Mark,My thought is it has it's own pump,filter, and oil tank.
I like that idea only for the fact it will not contaminate my tractors oil. And being a separate sys. if I blow a line or somehow cause a leak the tractor is fully functional.
Just My thought!
Phil
Here is a Pic.
   / Tractor has new Baby #6
Hi Phil - I have a 1260 also and been lusting after a backhoe for sometime. Do you have any photos of the subframe that you built?
Also do you have to take your subframe off to use the 3 point?
Regards
Barry
Hi Barry,
I will attach a picture of the back end for the subframe.
I have a woods loader and the bottom frame for that may be different than a MF frame. I used 2 5"x5" H-beams front bolted to the woods under frame. At the back of the tractor I used the 1.5" hitch bar . I welded 2 3"x3" sq tube across the beams to hold up the weight of the Bh. I did notch the bottom tube so the bar would slide though. I also added 2 1.5" tubes to the top of the beams to act as a bumper under the rear axle perchases. I used the bottom mount arm on the Bh and end bolted to the H-beam. The Bh also comes with a top link connector and braces for the 3pt. that is where it belongs except I did a mod to the braces and reversed the an connected to the top of the beams. Now there is only a load on the top link tha is very light. You can still pull the pin out with all of the Bh weight .
I can send more pics if you need.
"Also do you have to take your subframe off to use the 3 point?"
Yes the frame comes off with the Bh 3 Bolts, and 2 pins.
Phil
   / Tractor has new Baby #8
Hey Phil, Looks good ... Could you tell us what is the digging depth, length in reach and does it seem to have plenty of power? Thanks...Mark
   / Tractor has new Baby #9
philbuilt said:
Hi Barry,
Phil
Thanks Phil - that helps a lot - will have to get underneath mine to see what the set up is.
Barry
Hi Mark,
It will dig 6'-6" it has plenty of power for it's size. I would assume that the reach is 7' or so out the back. It has a really good side to side reach as well.
Electric Parts Movers (A50121)
Electric Parts...
(4) Semi Tires (A50121)
(4) Semi Tires...
AGCO Sunflower 20' PT Disc Harrow (A50120)
AGCO Sunflower 20'...
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
