Buying Advice Tractor for converting cleared forest land to row crops
   / Tractor for converting cleared forest land to row crops #21
I've always heard them called "loader -crawlers" or "track-loaders" . I suppose it depends on where you grew up. ;-)
eta
That looks like some nasty grounds for anything on rubber.
You best get in a track vehicle to smooth things out.
   / Tractor for converting cleared forest land to row crops #22
checkout
tractorhouse = agriculture machinery and tractors
TractorHouse.com | Used Tractors For Sale: John Deere, Case IH, New Holland, Kubota.
machinerytrader = sister site of tractorhouse and deals with industrial equipment
MachineryTrader.com | Backhoes for sale, skid steers, excavators, dozers.
everythingattachments = good stop for newbies to watch videos of how to install/setup and use various attachments for tractors
Tractor Attachments And Skid Steer Attachments For Any Tractor Or Skid Steer
above 3 sites, take a look around to see what is out there, even if used and old. it still gives you an idea of different equipment of what is out there. and might be easier for you to stay in a conversation when asking local companies to come in and clean stuff up.
Well, I've had quite a crash course in tractors over the last six weeks and I have updated my requirements several times now. I'm glad I gave myself time to figure things out. Since I won't be able to start until next year now, I have more time to get an education. I have arranged to have the land flattened by a dozer over the summer, which will save me a lot of time and pain. I will still have a lot of debris in the soil, so that will be the first problem to solve. I'm thinking of using a ripper to hit on anything big and then proceeding directly to a heavy duty tiller. I've gotten mixed advice on that idea. Everything from just start with the tiller to don't even bother with a tiller until you've worked it over with a disc for a few years. Probably an idea subject to further refinement.
I've resolved to probably spend about twice as much as I hoped to on a tractor. The problem is that it is not easy to find a tractor that is both well suited for doing the heavier work of cleaning the place up and then the ongoing work of row crop maintenance. In some ways, it would be better to buy two tractors, but that is definitely not in the budget.
Having looked at some Mahindras, Masseys, Kiotis, and Bransons now, I favor the Branson 7845C and the Kioti NX6010 Cab. They are pretty close in price. One of the big problems that I found in the next step down from those models was minimal ground clearance. That would really limit cultivation in established crops. The Kioti is about 16 inches, which seems just barely workable. The Branson has a more comfortable 18 inches. They're not really in the same class, as the Branson is a much heavier tractor, but that seems to fit well with my soil prep needs. 6000 pounds ought to give some traction. I also really liked the synchro transmission and creeper gear on the Branson. On the other hand, I'm a bit leery of Branson since they are such a small outfit. The Kiotis are also really nice and have a great dealer close by, so they're certainly not out of the running, but there aren't any of the larger ag type RX models locally, which might compare more favorably with the Branson. Haven't looked at Kubota yet, as I couldn't get anyone at the dealer to acknowledge my existence.
There are a lot more options if I don't want a cab, but it rains more than 100 inches per year here and buying a tractor without a cab seems like a decision I would probably regret.
   / Tractor for converting cleared forest land to row crops #24
Having just converted several acres of trees to cropland I will give you some advice. After I had a dozer and highlift in I came back over the ground with a grader box with all the tines down all the way to try and rip up the roots, did this several times and having a larger HP tractor will be needed. After several passes we used a landscape rake, and the next step will be to hit with my heavy duty disc, the last step will be the KK tiller. I want to make sure I get most of the roots out before going over with a tiller. I have pulled roots that are 12 ft long and as big as my legs so the tiller would be in bad shape if I didn't do the cleanup first. Good luck
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2018 Deere 323E (A53317)
2018 Deere 323E...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
