Tractor Sizing Tractor for 20-50 acres
   / Tractor for 20-50 acres #31
400 acres here, around 150 get mowed, rest is timber. The last 10 years we've taken care of the place with an old L3750, 1984 model, 45hp. I just got a L3800, 38hp. Now have a two tractor farm. :D
Ya don't really need a large tractor, but if ya want one, get it. :thumbsup:
   / Tractor for 20-50 acres #32
Also, my brother is logging with a little 23hp Massey 4WD. He can snake logs out of the woods where the larger tractors can't. :cool:
   / Tractor for 20-50 acres #33
Only about 10-15 acres is grassy, and the rest is wooded. We plan to selectively remove some trees though.
30-40hp would be fine then. Six foot implements are a good size for 10-15 acres. No reason to get greater than 40hp, just make sure that you get a decent loader with at least 1500-2000lbs lift to help with the tree removal.
   / Tractor for 20-50 acres #34
Just bought a 100 acre farm - mostly wooded and horses take care of the pasture. We ordered a L3200 and figure it will be fine for what we need. Will rent or borrow if we need something bigger.
   / Tractor for 20-50 acres #35
And it'll do a fine job for ya! Congrats! :thumbsup:
   / Tractor for 20-50 acres #36
You mention working with "large" trees; depends on your definition of large. My 50 HP tractor won't budge some of the trees with which I have worked. We used our Massey Ferguson 375 72 HP 4WD loaded tires and cast centers to pull them out. I have two trees down right now that I am going to have to work up or get the 8540 down in there as my other tractors just won't do it.
   / Tractor for 20-50 acres #37
It also depends on how much a guy wants to spend. $$$
   / Tractor for 20-50 acres #38
Almost always a consideration for sure. I didn't particularly "want" to spend the money, for us, nothing else worked.
   / Tractor for 20-50 acres #39
True that. I tend to get by with less, because of the money.
   / Tractor for 20-50 acres #40
Advice on TBN is almost always more more more horsepower etc. Maybe we need a new subforum for "small is beautiful" tractors.
20hp is plenty to get a lot of work done so long as there is no critical time element.
More info coming soon! (A55851)
More info coming...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2020 FREIGHTLINER...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
golf cart electric (A55787)
golf cart electric...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
