tractor engine side panel fasteners
/ tractor engine side panel fasteners #1
rbig
What I'm asking about applies to garden tractors with removeable side panels around the engine area.
For those not too familiar with the situation, my panels are held in place with bolts passed through holes at the corners of the panels, into threaded anchor holes in the frame.
What's happened is that, over time, some of the anchor threads gotten degraded so that the previous owner(s) have drilled and threaded to the next larger size. This isn't too bad, but does result in a mixed bag of bolt sizes. And yes, I could simply drill and thread the remaining smaller ones to the next larger size so I would have all the retainers the same size.
Drilling out the threads and using nuts on the backside of the frame anchor points isn't really a solution, as some of the areas are not easily accessible for holding a backup and even getting a nut on.
I'd like to put some kind of fastening scheme in place which would enable me to quickly remove and install the panels.
One thing I though about is drilling the anchor threads out, putting bolts through from the back side, running outside nuts down tight on them, putting the panels on over the threaded "studs" sticking out, and putting wing nuts on the secure them.
Just wondered if others have been down this path, and what you did to solve the problem. Are there any kind of quick release type fasteners which are readily adaptable to solve this problem?
/ tractor engine side panel fasteners #2
I'm wondering if some type of speed nut might best fit your application. I have used a tinnerman type clip for more than a few applications myself, although never needed on our TC-40D SS. McMaster carries a few different styles click here
Once you get to their site type speed nuts into their search engine.
/ tractor engine side panel fasteners #3
Hi Rbig
I have a JD 214 with side panels on it like you discribed. they are held on with 1/4" cap screws. Then on the back I always called them clip nuts. They sell them in most any hardware store. As PineRidge said they are in McMaster Carr under speed nuts, then Panel nuts, then a last U-nuts.
Hope this helps.
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
SWACARS 20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
SWACARS 20' SINGLE...
LOT LOCATIONS (A59908)
2021 CATERPILLAR 300.9D MINI EXCAVATOR (A62129)
2021 CATERPILLAR...
Deere 335P (A53317)
Deere 335P (A53317)
2019 PETERBILT PB520 GARBAGE/SANITATION TRUCK (A59823)
2019 PETERBILT...
