Tractor Electrical ?
   / Tractor Electrical ? #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
I have installed a 6 position fuse panel rated for 180 AMPS in my tractor to run the following:
1. Front Work Lights 55W
2. Rear Work Lights 55W
3. 3 Speed blower for heater
4. Radio
5. Dome Light
6. Empty
My question is this, what size wire should I run from my battery to the fuse block, it is around 12' from the battery to the fuse block, should I use 8 or 10 gauge?
-Mike
   / Tractor Electrical ? #2
Without knowing how much power the blower/radio/dome light actually draw, it can be a tough call. To size the wire to the 180A of the fuse panel would take about 1/0 AWG over twelve feet. I'm sure that's overkill for the actual loads you're putting on. What size fuses do you have in each slot?
If you have a 5A fuse in each slot, you'll tap out at 30A and can use the 8AWG.
-rus-
   / Tractor Electrical ? #3
if he's needing 180a.. he needs a nice beefy alt too!
I agree on the 8awg.. 4 if he had some sustained loads like a inverter.
soundguy
I do not need 180A, I was just telling you all that it is a 6 pos, fuse block rated for up to 180 Amps.
Thanks for the advice guys, I will go with the 8 Ga.
-Mike
   / Tractor Electrical ? #5
if i understand what you said correctly, you are going to run an 8 ga wire from the battery to the fuse panel with a run of 12 ft. the 8 ga wire needs some kind of fusible device as close to the battery as possible. if not fused thats a sure fire starter if it ever shorts to ground ,which is not an unlikely scenario on a tractor.
   / Tractor Electrical ? #6
  • BambiCam-Wire ANSI D R1 11x17.pdf
Thanks guys, I wasn't thinking about the inline fuse untill you mentioned it, that could have been real bad!!
Mjn,
Excellent drawing, I will have to steal some ideas from it, thanks again for your help.
-Mike
   / Tractor Electrical ? #9
Whatever size you use, just make sure that it is the flexible type, not the normal 7 strand building wire...and fuse it
   / Tractor Electrical ? #10
JJ,
Do you have any other info, if someone wanted to purchase one?
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2012 Honda Accord LX Sedan (A51694)
2012 Honda Accord...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
