Tractor DRAWBARS & CROSS DRAWBARS Illuminated
   / Tractor DRAWBARS & CROSS DRAWBARS Illuminated #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
CROSS-DRAWBAR ~~ PHOTO #1
A tractor cross-drawbar mounts through the "bullseyes" integral to the left and right Lower Links of the Three Point Hitch then secured with lynch pins. An inexpensive fitting, known as a drawbar lock, Photo #3, couples the cross-drawbar and one Lower Link to prevent the cross-drawbar from twisting/turning on its axis. Alternately to a drawbar lock, a substantial vertical component, Photo #4, is bolted to the cross drawbar, adding a Top Link connection and a receiver hitch at the base. A third option is an integrated, triangulated cross-drawbar, Photo #5, which includes a Top Link connection. Option three is the high value hardware.
Cross-drawbars are readily available in 20" width for subcompact tractor, 26" width for Category 1 compact tractors and 38" width for Category 2 tractors. Cross-drawbars accept accessory clevis and bolt-on installations. Several attachments are visible in photos. Mild steel is used for cross-drawbars so they bend, gently, rather than fail catastrophically under a heavy load.
A cross-drawbar allows elevation of pulled loads using Three Point Hitch hydraulic power. With 4" to 6" of elevation loads are unlikely to encounter obstructions either stopping the tractor or driving the tractor vertical if the operator in not alert.
(I once had a Deere 750 vertical, towing timbers from the rear/center drawbar.)
With loads elevated on a cross-drawbar less of the load is in ground contact, decreasing friction of the load against the ground and preventing the load from plowing dirt. In some circumstances elevation permits heavier loads to be pulled.
Photos #6 - #8.
The disadvantage of a cross-drawbar is its integration with the Three Point Hitch, a weaker connection point than the tractor frame/chassis. An imprudent operator could damage the Three Point Hitch with imprudent loads or imprudent operation. With loads perpendicular to a cross-drawbar substantial strain is placed on perforated, mild steel bar. Most cross-drawbars in use for some time show distortion but remain functional; mine included, Photo #4.
Any time you are pulling a load with a tractor, the load is trying to pull the tractor over backward. The Three Point Hitch relies on "tongue weight" (mass of the load bearing down on the Lower Links) for vertical stability. The Three Point Hitch does not include a latch to prevent unanticipated upward movement of the Lower Links, cross-drawbar and a wheeled load. Photo #9.
Sudden reversal of tongue weight may occur as cart load is pulled up a slope, over uneven ground, if a cart is inadvisedly loaded at the rear first rather than the front or center first, or if someone steps on rear of the load, shifting weight distribution to the rear. Caution with two-wheeled drawn implements is also advised, for identical reasons. The potential for load upset, tractor upset and human injury is there.
The Three Point Hitch and optional cross-drawbar are designed to pull heavy loads at or below rear axle height, over level ground, with minuscule risk of a backward upset. When the cross drawbar is raised above rear axle height, the potential for a backward upset increases. Always position Lower Links and cross-drawbar at the level of the rear axle or as low as conditions permit.
REAR/CENTER DRAWBAR ~~ PHOTO #2
Integral to the tractor is a rear/center drawbar which is attached directly to the tractor frame/chassis. Rear/center drawbar does not elevate; it is fixed. Rear/center drawbar in photo has a clevis mount chain grab hook attached, a ubiquitous fitting. (Rear/center drawbar is often a new tractor factory option on lighter tractors.)
The advantage of the rear/center drawbar is its fixed attachment to the tractor frame/chassis, the strongest connection possible. On my kubota L3560 the rear/center drawbar is always in place. The rear/center drawbar does not interferes with Three Point Hitch implements nor the mounted cross-drawbar.
If you must pull a cart or two wheeled implement over uneven ground or up a slope, bolt on appropriate size hitch-ball to the fixed rear/center drawbar.
Photo #2 ~ Omni Mfg., LLC, Deerwood, MN Combo Draw Bar Trailer vertical component. (2/2012)
LINK: Combo Hitches - OMNI Mfg LLC
Photo #3 ~ Triangle Cross-Drawbar Hitch
LINKS (2): 3 point hitch drawbar in Heavy Equipment, Parts & Attachments | eBay
Tractor 3 Point Hitch Adapter, tractor hitch adapter
Google Images: TRACTOR cross drawbar - Google Search
   / Tractor DRAWBARS & CROSS DRAWBARS Illuminated #2
Good write up!...
As a thought and mentioned in another post somewhere on this forum one could use a limiter chain to prevent upward movement of 3PH due "sudden reversal of tongue weight" ...
Its probably one of the little things (obscure) we are not always aware of....
Dale
   / Tractor DRAWBARS & CROSS DRAWBARS Illuminated #3
From some years ago. One of the nicer ones.
I put a steel cross bar that fits in the two lower units of the 3 point hitch. The arms on those are about 5/8 thick steel. Logs are chained to the cross bar to lift and then I pull the logs. Concerned that may cause too much strain on the 3 point hitch system as TPH was designed more for bush hog mowers etc, not heavy lifting and pulling.
The steel cross bar is known as a CROSS DRAWBAR. They are made of mild steel, so they will bend, rather than snap, if overstressed. In timber work, you rarely encounter a straight CROSS DRAWBAR. The CROSS DRAWBAR has two advantages: 1) It lifts one end of a timber, reducing friction over most of its length when pulled. 2) It lifts one end of a timber so that the timber is LESS likely hang up on a rock, root or a burrow, instantly pulling tractor up onto its rear wheels, especially pulling tractor loads uphill. (I have personally experienced this, skidding logs over flat ground with a REAR/CENTER DRAWBAR attached to a Deere 750.)
MORE: 3-Point Hitch - Tractor Three Point Hitch CROSS-DRAWBARS
Tractors are designed to PULL over level ground.
a low receiver type opening that appears would be more substantial to pull on and with except that has no lifting capability so the entire log for the most part would have to dragged in the mud as opposed to just the end if it could be lifted in part above the mud.
The rectangular attachment which fits into this receiver hitch is known as a REAR/CENTER DRAWBAR. Receiver is attached directly to the tractor frame. Attached load is pulled at or below level of the rear axle. This is the correct point at which to attach heavy towed loads.
Tow slow so that the timber will not hang up on a rock, root or a burrow, instantly pulling tractor up onto its rear wheels, especially pulling tractor loads uphill.
MORE: Rear/Center Tractor Drawbar // USE TODAY
One reasonably SAFE way to skid logs up a slope is using a Three Point Hitch, PTO-powered log-skidding-winch. The tractor remains on flat, unchurned ground at the top of the slope.
VIDEO: https://www.youtube.com/results?search_query=COMPACT+TRACTOR+LOG+SKIDDING+WINCH
I was asked to help skid heavy logs up muddy, fairly steep hills.
You cannot enjoy a tractor if you are dead.
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
FENCE PANELS (A58214)
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
