Tractor decking - White Oak vs. Pressure Treated
   / Tractor decking - White Oak vs. Pressure Treated #1
HawkinsHollow
SE TN
Branson 3015R
I need a new deck on my trailer. I have a sawmill but do not have any white oak logs long enough to serve the purpose. BUT, if white oak is going to be that much better than pressure treated wood I will find one.
So my question is: What is better white oak deck boards with the oil/diesel treatment or pressure treated 2x6s? If white oak is the answer, is it THAT MUCH better to go through the trouble of sourcing a white oak log to mill the boards out of? This trailer will primarily be used for moving logs and my trailer. The log loading process will probably not be very kind to the trailer decking.
The old timer that I usually ask about such things seems to think that white oak will be substantially superior to pressure treated. What says ye?
   / Tractor decking - White Oak vs. Pressure Treated #2
White oak will be stronger than PT pine of the same dimension. White oak (but not red oak) has the reputation of being decay resistant. If needed, a sawmill can also saw it thicker for you than what you'd find at a box store, but you might have to do some trailer modifications to install it.
Not implying you can't saw it yourself, but some guys do this enough and have sourced white oak that it might be less hassle for you to buy the material from them.
   / Tractor decking - White Oak vs. Pressure Treated #3
The white oak is going to be MUCH tougher!
PT lumber isn't nearly as strong and you still have to oil it.
SR
Not implying you can't saw it yourself, but some guys do this enough that it might be less hassle for you to buy the material from them.
That would negate the purpose of buying a sawmill. But yeah I hear you. Seems like 2x6 white oak trailer decking could be a bit on the costly side too.
   / Tractor decking - White Oak vs. Pressure Treated #5
Do you have any locust growing around you?👍
   / Tractor decking - White Oak vs. Pressure Treated #6
I have a small utility trailer that I rebuilt 50 years ago with pressure treated,out-side the whole time;is STILL good and still use it.
Yeah, I have a 5x8 trailer that I bought 10 years ago that old PT 2x6 on it. They ain't pretty but they still work fine.
PT boards 50 years ago are alot difent than they are today though.
   / Tractor decking - White Oak vs. Pressure Treated #8
I re decked my GN with Apitong which is the wood of choice for every commercial trailer builder. Stuff lasts forever and is impervious to rot and is structurally superior to common pine or oak.
It all depends on how often you want to re deck the unit. Apitong isn't cheap.
   / Tractor decking - White Oak vs. Pressure Treated #9
The price was comparable when I bought white oak from the local sawmill maybe 10 years ago because you aren't paying for all the big box store markup.
You are looking at about $40 for a 2x6x16 White oak deck board on FB marketplace. PT is $17 at home depot.
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2008 UTILITY DRY VAN TRAILER (A52576)
2008 UTILITY DRY...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
23222 (A50323)
23222 (A50323)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
