Tractor cover
   / Tractor cover #1
logangrey
Western NY
LS 3032
Hi guys I have an ls3032 a would like to get a cover or partial cover for it. Maybe try and keep it looking goid longer. I store it inside in winter but outside in summer mostly soprevent damage to paint and plastics . Any ideas . Thanks
   / Tractor cover #2
Metal carport would be the easiest and cheapest route. That's what I have.
   / Tractor cover #3
May not be as easy as the carport, but possibly cheaper. I am planning on doing something like this on a remote parcel I own. Total cost should be around $500 as of 5/2/2023, but I am using logs I have on site and leaving the sides open.
   / Tractor cover #4
If you don't care what it looks like, and are not concerned about snow load (summer months) then make a simple frame using 2x4 and a tarp from Harbor freight. Make it wide enough and tall enough to fit your tractor.
A bit more expensive, but under $500 and easier than all these, is a popup tent. Here is a 10x20 that should fit your tractor with room to spare. Would probably need to fold down your ROPS
   / Tractor cover #5
Soft tarp maybe.
   / Tractor cover #7
This is what I have - works great and I have implements in there with the tractor. Its heavy duty been using it for 6 years so far can handle snow loads and wind and a tree fell on it and didn't rip or break anything.
https://www.tractorsupply.com/tsc/p...-peak-style-12-ft-x-20-ft-x-8-ft?cm_vc=-10011
How does that hold up to wind load?
I live in eastern NC and snow is not a concern whatsoever. The wind is a problem for me though. I currently have a makeshift tent in the woods with a large TSC tarp and 1/4" cable. I am constantly fixing it due to wind and the pucker-factor is high come hurricane season.
   / Tractor cover #8
Over time, a carport or DIY tractor shed with a metal roof is going to work a lot better than replacing tarps.
   / Tractor cover #9
It's not expensive or hard. 6 each 4x4x12; 12 bags quikcrete; some 29ga roofing tin, 2x6x12 shed roof joists, some 2x4 purlions. Probably cost you less then $250. I would go with something in the neighborhood of 12x16 ft. Over hang about 2 ft of the sides; simple shed roof; 1 in 12 pitch (unless you live in snow country). Space your 4x4s at 8 from OC; and you can span a 12 ft space with a 2x6 if your just holding up 2x4 purlions and 29ga metal. If your working by yourself; you might get 9 ft pieces of metal roofing rather then 16s. Give a health over lap. Done. Unless your county beats you up about permits. Then the "engineered roof trusses" end up probably tripling your cost.
Edit; generally roofing metal is Far more expensive at Home Depot or Lowes then a metal roofing supplier
I would set 4x4s about 24-36" in ground, mix and pour 2-80# bags of quikcrete on them; make sure to temp brace until roof is finished. Probably make the high side of the shed 10 ft. the low side 9 ft. Attached generic Google images.
View attachment 799090View attachment 799091
2015 Chevrolet Impala Sedan (A49461)
2015 Chevrolet...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
Online Buyers Premium (A47384)
Online Buyers...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
