Tractor cover?
/ Tractor cover? #1
dmnsmith2
Alabama
03 Kubota B7800
I am looking for a cover for my B7800. Would like to protect it from the weather. Anyone? Thanks in advance!
/ Tractor cover? #2
Hi...
How often will it be covered & uncovered ? Thinking convience...
Stored ouside or in building ?
Any snow there ?
Dave...
/ Tractor cover?
I have it in the garage now, but need to move it outside. It barely snow's here. The tractor will be covered most of the winter. Probably used once ever 10 days or so in the spring, summer and fall.
/ Tractor cover? #4
By cover, I don't know if you refer to the fitted type that is used for cars or the canopy type with a metal frame. I have never seen a fitted type cover advertised but you might want to check out www.calcarcover.com. They specialize in custom fitted covers.
/ Tractor cover? #5
Hi...
This is a convienient way to cover it... your own tarp sides can be added... from Farmtek.com
"Starting at $569"...
...or... building a simple sloped roof may be less expensive...
...like a lean-to against the garage...
If a regular type poly tarp is put right on the tractor... expect it to scratch/wear the paint from wind movement... may/may not matter to you... this is a low cost thing to do... maybe $25 ?
A canvas tarp may be somewhat better... less harmful... more $$ than poly though...
Maybe old sheets/blankets sewn together ?
Dave...
/ Tractor cover? #6
<font color="blue">The tractor will be covered most of the winter. Probably used once ever 10 days or so in the spring, summer and fall.
</font>
Once EVERY TEN DAYS !!!!???? /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
Well...I'm not a bettin' man...but I sure bet them are famous last words!"
Especially seeing that you got a loader on that tractor. /forums/images/graemlins/smile.gif
/ Tractor cover? #7
You might want to consider putting plastic under the tractor as well to keep moisture from coming up from under the ground. The tarp alone on top can trap moisture and hold it in there on your poor tractor.
/ Tractor cover? #8
i go along with dave's thinking some type of canopy or leanto, better than just throwing something over the tractor, gets to hot, or creats moisture.
/ Tractor cover? #9
My .02:
Consider the wind too. Maybe you are fortunate and don't have much, but around here a good windstorm can last a couple of days with gusts 50+ MPH.
After that, a cover will have flapped itself to shreds and/or sanded the paint right off the tractor where it rubbed.
A canopy is a better choice but must be anchored well so it can't fly off in the wind and cause injury or property damage.
/ Tractor cover? #10
I also have a b7800 and hav e determined that it does not take much wear for the paint to disappear especially where one steps to get seat time. I think a flexible cover of any type will be hard on the paint. I purchased free standing car port type for mine 18 feet by 20 feet for 595.00 which is more than enough room to store other equipment out of the weather just my 2 cents $00.02
/ Tractor cover? #11
</font><font color="blue" class="small">( I have never seen a fitted type cover advertised but you might want to check out )</font>
Ford used to make a 'storm' cover, that was a fitted cover for some of its tractors. It no longer does as far as I know.. but there are aftermarket places that do. I would suspect that each 'brand' has somehting similar.. though have only seen the ford storm covers..
Soundguy
/ Tractor cover?
Thanks all for the input. Certainly many options to consider.
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
2002 John Deere 544H Articulated Wheel Loader (A61572)
2002 John Deere...
4' FIELD CULTIVATOR (A63291)
4' FIELD...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
