Tractor Capabilities VS. Attachment
   / Tractor Capabilities VS. Attachment #1
FlyingPRanch
Kubota B2910
Morning,
I am in the market for a brush hog but do not know much about it. I have a Kubota B2910 (25 HP PTO??). Cutting about 5 acres of horse pasture. The pasture has been kind of neglected but does not have saplings (maybe a handful), just a bunch of random grasses and weeds. I plan to rehab it and plant fescue.
So my question is; can I get away with a 5ft light duty mower? Will this be to much strain on the tractor? If so, maybe a 4ft medium duty? Reasonably priced brand suggestions would be great too.
Thanks!
   / Tractor Capabilities VS. Attachment #2
I don't have a "brush hog" yet but everything I have read seems to say the mower should be at least as wide as the rear tire width of you tractor... My SCUT with wheel spacers is 47.5 inches and has 19hp at PTO so it seems to me a medium duty 54 inch mower would be the ticket for me...
   / Tractor Capabilities VS. Attachment #3
I think you will have no problem with a 5' cutter. I have run a 5' Rhino brush cutter on my B2710HST that has about 19hp at the PTO for 20 years with no issues. I cut a 5 acre field once a year that grows some good saplings in that timeframe. Rule of thumb I followed over the years was about 5 PTO hp per foot of brush cutter.
   / Tractor Capabilities VS. Attachment #4
21hp massy has ran a 5 ft woods mower for 10 yr. for lawns. it struggles in 12 in high grass.
a five ft bush hog is a strain and i would not run one very much on this tractor with 17 hp at the pto.
a 24 hp would run a 6 ft woods type in light grass and should handle a 5 ft bush hog. heavy grass would strain a 6 ft woods.
   / Tractor Capabilities VS. Attachment #5
I sold my brush cutter and bought a 7' Woods rear discharge finish mower that does a much better job on pastures. Set the height up initially to 8-10" or so, then groom it down. I can run in top gear now. not even on the governor. Ground speed is the regulating power on my fields, not tractor H.P. Slow initially. The comments on a wide enough machine are right on. That's why I went with 7'.
   / Tractor Capabilities VS. Attachment #6
a neighbor has one of the 7 footers and i sure like the way it cuts.
i would consider one for sure.
   / Tractor Capabilities VS. Attachment #7
Kubota B2910 Dimensions​
Kubota B2910 tractor photo
2000 - 2005
B Series
Compact Utility tractor
Series:B2710B2910
Kubota B2910 Tires
Ag front:7-12
Ag rear:12.4-16
Lawn/turf front:24x8.50-14
Lawn/turf rear:13.6-16
Industrial front:23x8.50-14
Industrial rear:12.4-16
Dimensions
Wheelbase:65.6 inches
166 cm
Length:99.2 inches
251 cm
Width: R1/Ag Tires53.8 inches
136 cm
Height (ROPS):78.5 inches
199 cm
Dry Weight:1,763 lbs
799 kg
Ground clearance:14.6 inches
37 cm
Page information
Last update:March 6, 2020
Copyright:Copyright 2020 TractorData LLC
Contact:Peter@TractorData.com
Engine Detail Kubota Model V1505-E-D16 diesel, 4-cylinder, liquid-cooled, Displacement: 91.5 ci = 1.5 L
Bore/Stroke: 3.07 x 3.09 inches
78 x 78 mm
Power (gross): 30 hp / PTO: 22 hp
Rated RPM: 2600
I am in the market for a brush hog. I have a Kubota B2910
with 22 HP PTO. Cutting about 5 acres of horse pasture. The pasture has been neglected but does not have saplings (maybe a handful), just a bunch of random grasses and weeds.
So my question is; can I get away with a 5ft light duty mower? Will this be too much strain on the tractor? If so, maybe a 4ft medium duty?
You will be fine with a light duty 60" Rotary Cutter weighing 400/450 pounds. 400/450 pounds will be a good match to your 1,800 pound bare weight tractor and 22 PTO horsepower. You should be able to mow dry grass 40" tall, full 60" swathe width.
Mowing Calculator: Mowing Calcuator | How many acres can I mow in an hour
MORE: Rotary Cutter / Bush Hog Considerations for Compact Tractors
Almost all Rotary Cutter components are sourced in China or South Korea these days.
Consider optional chain debris guards so you can mow backing the tractor.
   / Tractor Capabilities VS. Attachment #8
B2910 develops its rated horsepower at 2,600 rpm.
I had a Kubota B3300SU with the same engine.
If you do not attenuate the engine and transmission noise it will get to you mowing at near full throttle.
Here are the 3M ear plugs I use when mowing and highly recommend:
I've got a good pair of noise canceling headphones I wear while I'm on the tractor.
As far as your 1st comment; are you saying I need to run the tractor at 2,600 rpm in order to operate the brush hog effectively?
Do I need to worry about gear box rating when I purchase?
   / Tractor Capabilities VS. Attachment #10
There should be a mark on your tack for 540 PTO rpm which is what you want to run most rear pto implements, that is its effective speed, it is not at max throttle. It has been a few weeks since I was on the tractor but I think it is somewhere around 2400 tractor rpm. If you get a 5' brush cutter, it will be rated for way more HP than your tractor has or if your wondering about PTO speed, the gearbox is geared to work at the 540 pto rpm standard although you can run it less if the conditions allow it.
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2016 Ford Explorer...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
