Snow Tractor blows smoke and bogs down
   / Tractor blows smoke and bogs down #11
Black smoke usually means too high fuel/air ratio like a clogged air inlet or air filter. You say you changed the air filter.
Did you look at the inlet ducting upstream and downstream of the air filter?
If the tractor is underpowered and not blowing black smoke then I'd say you have restricted fuel flow and that's usually a clogged filter or some debris in the fuel tank that's clogging the fuel outlet on the tank. Check the fuel flow out of the filter. It should pretty well gush out continuously. If it dribbles or is intermittent, start working your way bck to the tank out let looking for pinched lies, etc. Some tanks have screens on the outlet and they can clog with debris or bacterial contamination from water condensation in the tank.
   / Tractor blows smoke and bogs down #12
I'm with Jerry/MT.
Check for a clogged air filter.
2012 John Deere 7230R (A55314)
2012 John Deere...
2004 Jeep Liberty Limited SUV (A55853)
2004 Jeep Liberty...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
