Tractor backhoe - homemade
   / Tractor backhoe - homemade
Started making the bucket...got the sheets back from bending shop...they made a mistake, wrong upper angle but I will cover this with a little triangle and it will be fine. Originaly it should have followed side plate shape...
   / Tractor backhoe - homemade #1,272
That looks fantastic. How thick are the sides?
10 mm sides, 5 mm bottom sheet, 12 x 100 mm hardox cutting edge and side edges. It will have 4 sliding plates, and some reinforcement plates at the back side under the coupling
   / Tractor backhoe - homemade #1,274
Looks good. Our Deere's FEL bucket has roughly 10mm x 100mm wide reinforcement under the bucket in line with the couplings. It goes all the way underneath to the cutting edge.
   / Tractor backhoe - homemade #1,275
I’ve really enjoyed following this whole thread! Keep up the great work and keep posting updates!
Some turning and welding...
   / Tractor backhoe - homemade #1,277
WOW! that is shaping up to be a nice FEL. You may have mentioned earlier about the bucket and or forks. Are you going to build them from scratch also?
The bucket is almost done and I made the forks earlyer.
   / Tractor backhoe - homemade #1,279
I keep expecting to check this thread to find that you've started building your own tractor from scratch. The backhoe and loader are going outclass the tractor.
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
