Tractor backhoe - homemade
   / Tractor backhoe - homemade #1,111
great fab skills,looks awsome,and very STRONG, keep them updates comming,
Godbless
   / Tractor backhoe - homemade #1,112
Coupling in place, first check on the tractor
Are you using the same mounts as your previous backhoe, or did you build new mounts?
I left the previous frame on the tractor. It could not be fitted to a different tractor, one would have to build a new subframe. It's like front loaders, they make them all the same, you just need a frame for your type of tractor. Right now this is an advantage because I will build it quicker ;)
   / Tractor backhoe - homemade #1,114
That's seriously good renderings and commerical quality subframe. Impressive work.
   / Tractor backhoe - homemade #1,115
Work for yourself and market your products. If you can do that you will be more successful than being an engineer for someone else. Your talent is envyable. I'm speaking as a non technical type that has worked for himself for the past 28 years.
Great stuff!
Thanks EKlee, I will try to start my own little buisness.
Today's work, main frame at 70%
   / Tractor backhoe - homemade #1,117
How are you going to make it slide, weld heavy flatbar against the tube frame so it will be like a FEM forklift frame ?
Yes, heavy flatbar 120x20 mm, 30 mm above and below tube
Welding it :)
   / Tractor backhoe - homemade #1,120
Excellent work as usual! Are you going to make the side shift hydraulically adjusted or you just slide it with the boom?
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
New Land Honor Heavy Duty Plate Compactor (A59000)
New Land Honor...
HUDSON BROS 9 TON PINTLE HITCH TRAILER (A52708)
HUDSON BROS 9 TON...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
Enmark Z Spray (A53316)
Enmark Z Spray...
Hose Reel (A55787)
Hose Reel (A55787)
