Tractor backhoe - homemade
   / Tractor backhoe - homemade
Thanks. I hope we win the gold. Best rank till now was 1998. 3rd place...
The whole hydraulic system, and finally first metal parts...kingpost hinges. The thickest material on the bh because it has to manage all the forces generated by the boom
   / Tractor backhoe - homemade #1,004
Elec. joysticks!! :cool2:
Those valves look conventional? I'm sure you have a plan.:thumbsup:
It will be a mixed system. Joysticks will have metal cable connection with those valves and two switches each so I can divert lines via 6/2 electric diverter valves. Not to expensive but very efficient :)
   / Tractor backhoe - homemade #1,006
For your info, the main boom of a Cat M314F we got in the shop last week, has 8mm top and bottom plates, all S355 quality. Havent measured the section height but its less bulky than your RK 525...
New bh will have 6 mm side plates and 8 mm top and bottom. How did you determine grade of steel on the boom?
   / Tractor backhoe - homemade #1,008
S355 is the only thing Cat uses... We modify booms and sticks for Cat and Hitachi importers, high reach demolition, long reach dredging, thats why we get the info when we need it for a modification.
Even the big mining excavators use just S355... If it has to last, you need more steel to lower the strain. High strength steel is only useful for static, or limited design life applications because the welds have the same, or worse, fatigue life before they start cracking, than S355...
HIAB truck mount cranes are Domex 700, but when you use those as a construction hoist crane instead of a truck loading crane, it will be cracked all over within 1.5 years because it will see the number of load cycles in 1.5 year which a truck mounted loading crane (used to self load a transportation truck as intended, not as a cheap alternative for a tele crane) sees in 15 years.
In civil engineering, the same fatigue life (or max strain) is used for S355 as well as the most exotic high strength steel. I contacted our steel supplier, and some research centers, and i found only some German research with hard, conclusive data about the differences in fatigue life between S690 and S355 base material (S690 base material only has a better fatigue life in low cycle, high strain fatigue) and in welded S690 and welded S355 (The S355 weld had a slightly better fatigue life)
Well I used S355 on rk 525 so you just convinced me not to buy Domex for this application. This will speed up my project because it will save me money. I've heard before about this cracking problem but figured they just don't wanna spend the extra money. Last time I used S355 J2 G3... is this the one? There are few types of it..
   / Tractor backhoe - homemade #1,010
Domex is good, because of its fine grained structure. But S355 or S420 is the max you get in fatigue strength, Domex 700 is only good for hoisting rigs with limited load amplitudes. Furthermore, high strength steel has higher carbon which needs preheating to avoid cold cracking and/or hardening effects along the welds.
But i think any S355MC has similar properties to Domex 355
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
