Tractor and acessories
   / Tractor and acessories #1
billyrayp
Bayview, ID
none
New to Tractorbynet.
Let me know how this forum works, with some responses. Thanks, billyrayp
so I was wondering about what to consider for getting a tractor, snow plow, bucket, grader, plow and mower. If $$$s wasn/t a problem I would go JD for the best, but I have to be frugal and may have to get cheapest, that meets my needs.
   / Tractor and acessories #2
Well, Mate, the first thing is to post this question in the proper forum as you'll get the responses you want. You've already introduced yourself so I'd re-post this in the Owning/Operating forum.
   / Tractor and acessories #4
Welcome to TractorByNet!
I moved your thread to the Buying/Pricing/Comparisons forum. :)
   / Tractor and acessories #5
:welcome: go for a used JD then.
   / Tractor and acessories #6
Welcome to TBN.
You might be more specific with your needs or tractor uses. Any tractor from a small 20 HP SCUT on up can use those attachments. Would 20 HP be enough or do you need 25,30,40 or more HP. Will you need 2 or 4WD, will the mower be a belly pan or 3 pt. I would guess your thinking used. You can also check your local CL for tractors for sale.
   / Tractor and acessories #7
Welcome, I am only a few months ahead of you in this idea of getting a tractor (for me a SCUT). To ask advice like this you need to let folks know what tasks you need to or want to do. Also you might (if you have not) look at TractorHouse.com and try to search for machines (mostly used or barely used) that fit your budget. If you are going older, Craig's List or Amazon? And use TractorData.com to review specs of various machines. These were the resources I used, and there are others I'm sure. I also did a lot of reading threads here on TBN. Good Luck!!
7046 (A50322)
7046 (A50322)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
2018 Ford F-550 Flat Bed Truck, VIN # 1FDUF5GTXJEC35552 (A51572)
2018 Ford F-550...
