Buying Advice Tractor Advice -The hunt is on.
   / Tractor Advice -The hunt is on. #1
hdmyers
North of Norland, Ontario
TBA
Good evening :)
After lurking for some time (and posting about my old forklift/snowplow) I find myself needing to maintain my property again.. I'm situated in Ontario... the 'Kawarthas'. near to Haliburton/Minden area. So we get a fair amount of snow.
We have 14 acres..most of it is left alone. I'm not looking to cut grass...but maybe keep a trail or two open.
We have ~1300 ft driveway. Nice gravel base. I'll need to plow/blow it.. and perhaps do some minor grading (not sure how reasonable it is to have gravel delivered and do repair/put down gravel with a machine vs having contractor do that)
So blowing snow, maybe front trip plow as well, loader, bushog...
I've looked at the L2601 and the Workmaster 25... seems the Kubota has cheaper price so far on the quote.. and that's with 2 remotes for the snowblower, along with the bush hog and loader.
Went to look at the L2601 series...it was bigger than I thought it would be. Even the BX didn't look too small.
Welcome thoughts/suggestions.
Cheers
HDM
   / Tractor Advice -The hunt is on. #2
You looking at a cabbed tractor if you get a lot of snow ?...........
   / Tractor Advice -The hunt is on. #4
While you're exploring see which tractors support a front snow thrower unless you don't mind going backward. A dealer nearby is better than a distant one - unless he's a total jerk out to rob you.
   / Tractor Advice -The hunt is on. #5
And you should consider a cab on the tractor. Due to where you live. It actually snows. And you'll want to stay warm.
Steve
   / Tractor Advice -The hunt is on. #6
I agree on the cabbed tractor.
I wouldn't even consider an open station for snow work.
   / Tractor Advice -The hunt is on. #7
Look at a Massey Ferguson 1745
   / Tractor Advice -The hunt is on. #8
A cab is nice for the wintertime, but in our area it sure isn't as handy as an open station with a canopy in the summertime.
Plus to cab or not has a lot to do with the operator's age and finances. I'm still in the "it's better to have a little nicer tractor than a cab." age group.
Bottom line is it's nice to have a winter tractor and a summer one.
rScotty
   / Tractor Advice -The hunt is on. #9
Canadians don't need cabs for snow blowing. . I may consider a soft cab down the road, but I am happy to be open station for everything else.
I would recommend a blower vs a plow unless maybe you have deep ditches. Even so, it would be much easier to blow it out of the way. Plowing any amount of snow will require chains. Definitely, a hydraulic chute control and hydraulic or electric deflector are required. I installed skids to reduce blowing rocks, but remove them once the base is frozen and covered. 1300 feet is a long driveway to be looking backwards but front blowers are very pricey and you lose your bucket. Pick up a used rear blower to start and try it for a year.
I have found driveway grading to be good fun (satisfying reaults) and I would certainly not pay someone else to do it. There are some good videos comparing blade types and approach.
Finally, I would encourage you to check out a Kioti if you have a local dealer.
   / Tractor Advice -The hunt is on. #10
Smart Canadians use cabs for snow blowing. Also older should make one smarter, learn from other's mistakes. A brisk wind even at -15 will take the smile off pretry quick.
Ford Disc, 2-piece Cone Bearings INOPERABLE/PARTS ONLY (A52128)
Ford Disc, 2-piece...
2011 Capacity Yard Jockey (A47384)
2011 Capacity Yard...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
2021 SELLICK S80 STRAIGHT MAST FORKLIFT (A51242)
2021 SELLICK S80...
