Traction Traction problems with Z-force
   / Traction problems with Z-force #1
Guido
Has anyone had problems with traction on a Z-force? My yard is sloped with numerous trees. Turning uphill is almost impossible. Tried wheel weights with some improvement. Anyone have any suggestions short of going to traction lug tires?
   / Traction problems with Z-force #2
Traction problems with a Z-Force?
It sounds like you are running the unit where its not suppose to be!!!
Take off the wheel weights.
If the hill is too steep and you are losing traction than you exceeding the limit on slope use. Which is 15 degrees or more.
You can't add weight to a Z-Force. You will shorten the life of the transmissions.
Zforces were designed to carry YOU and itself only.
Make sure you are mowing up and down the slope. Not across!If it's over 15 degrees you can't mow it. (a rise of 2.5 feet every 10 feet)
   / Traction problems with Z-force #3
</font><font color="blue" class="small">( problems with traction on a Z-force )</font>
Isn't that just the nature of the beast with ZTRs? /forums/images/graemlins/wink.gif I've got a Toro ZTR and it's great on flat ground, but any low spot, especially if it's wet, and you're stuck. /forums/images/graemlins/frown.gif
Maybe I just should of said that the tires furnished are lousy and does anyone have any experience with any different type of tire.
NEW HOLLAND L180 SOLID TIRE SKID STEER (A51242)
NEW HOLLAND L180...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
