Traction Traction Lock
   / Traction Lock #31
Sequence when tire traction fails is 2WD to 4WD to 4WD with differential lock to everything plus FEL (as, for instance, you're stuck in mud) to "find a neighbor with a tractor or large pick-up to pull you out". As to the differential lock, I use such only when going straight (or nearly straight) forward and backwards. Doing otherwise places a fair amount of pressure on the rear axle and differential, which, of course, is why use of the differential lock is not recommended on cement or other higher traction surfaces, and why it tears up the ground under the "inside" tire on a turn.
If you want to use the differential lock full time, good luck, and let us know how it turns out after a few hundred hours of use.
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2008 BOBCAT 323 J MINI EXCAVATOR (A57880)
2008 BOBCAT 323 J...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
